overall diameter question
Old May 15, 2007 | 04:35 PM
MikeyMo84's Avatar
so im thinking of upgrading my 17's to solstice gxp 18's....ive already basically figured out that the wheels will fit but my question is...the tires on the 18's have an overall diameter that is 1.5 inches larger than those of the 17's...is this going to cause problems with the various sensors in the car?? (abs, bcm, pcm, etc)???
fyi the 2 tire sizes are
205/50R17 on the 17x7's
and
245/45R18 on the 18x8's
if anyone knows of any other problems I will encounter doing this please let me know!!
prob gonna throw some winter tires on the stock wheels seeing as at amost 20k miles the pirellis are almost shot
Old May 15, 2007 | 04:48 PM
cobi's Avatar
I couldnt see it throwing off any sensors but the speedo and im not sure but you may get some rubbing with a tire that wide
Old May 15, 2007 | 04:51 PM
Remedy One's Avatar
A 235 or less will be better suited for the application.
Old May 15, 2007 | 05:44 PM
MikeyMo84's Avatar
i know but im trying to avoid having to take the brand new 245 goodyear eagle f1's off the wheels...im trying to buy them at work b/c we put 19's wheels on a car we have in stock so the OEM 18's w/ tires are just sitting in the shed out back.
Old May 15, 2007 | 07:35 PM
Erod's Avatar
Moderator Alumni
From using the tire calc on 1010tires.com......
http://www.1010tires.com/TireSizeCalculator.asp
Stock Tire - 205/50R17 Tire 1 - 245/45R18
Section Width: 8.07 in 205 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 5.5 - 7.5 in
Rim Width Range: 7.5 - 9 in
Overall Diameter: 25.07 in 636.77 mm
Overall Diameter: 26.68 in 677.67 mm
Sidewall Height: 4.03 in 102.36 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: 12.53 in 318.26 mm
Radius: 13.34 in 338.83 mm
Circumference: 78.75 in 2000.2 mm
Circumference: 83.81 in 2128.7 mm
Revs per Mile: 829.6
Revs per Mile: 779.6
Actual Speed: 60 mph 100 km/h
Speedometer1: 56.3 mph 93.9 km/h
Speedometer Difference: - Speedometer Difference: 6.413% too slow
I'd mount one and test the fitment.
Old May 15, 2007 | 10:47 PM
MikeyMo84's Avatar
lol im sorry u kinda lost me there...can u convert that to laymans terms for me??
Old May 15, 2007 | 10:50 PM
p7x's Avatar
p7x
^^^ya they are too big
Old May 15, 2007 | 10:51 PM
handyjoe's Avatar
I'm pretty sure that the offset will really screw things up.
I've talked about this with someone before, and I don't remember the numbers, but the SKY wheels tried on a Redline did not fit, even though they were 5x110.
Old May 15, 2007 | 10:57 PM
Erod's Avatar
Moderator Alumni
Could test one, but, yes, looks too big of course.
Old May 17, 2007 | 06:50 PM
MikeyMo84's Avatar
what about using spacers??? would that help and what size??
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
