Steering wheel shaking after new wheels/tires
Long story short, steering wheel shakes/jiggles with my new wheels/tires Enkei EKM3s 18x8 and tires are Potenza re760 sports 235/40/18 on stock ride height, but the thing is, it does it at random speeds, and random parts of roads, so I was thinking maybe since I have "Sport" tires, it sacrifices some comfort for grip and I'm just feeling more of the road? I tried to take a video when I was driving today, which I just realize is sideways
YouTube - Shaking steering wheel
Wow I'm so retarded, I told em I was gonna pass on it since I was lowering the car soon but I dont think its happening right away, Am I doing any damage to the car or just a shittier ride?
One other thing..make sure the wheel is HUB CENTERED..not just bolted up. Wheels should come with hub ring for hub centric mounting. Otherwise you could get imbalance ON THE CAR (although balanced OFF the car).
need to be a bit more specific. Does the wheel shimmy back and forth while holding on...or are you just feeling the vibrations through the steering wheel? A shimmy is an imbalance for sure..could be tires or could be wheels themselves. Either way, you should be able to balance that out....even with wider rims and tires. I'm gonna rule out anything else (suspension) because this all started with the new stuff. The stock set up (my car) is smooth as silk...so should your new set up.
It's deff the tire balance that I need, there's no vibration, the wheel just jiggles back and forth slightly
Here is a link to order them for our car and Enkie wheels:
Hubcentric Rings for a 2009, Chevrolet Cobalt SS with Enkei wheels - JustForWheels.com
I have no idea, I never took the wheels out of the box, all I know is I got wheels, and then they said they found locking lugnuts in the box, I don't think they'd mention finding hubcentric rings to any normal customer though haha
Take a wheel off and see by yourself.
I had the same issue back when I had my cobalt,I just put some hubcentric rings on and the shaking was gone
Does the steering wheel also shake when breaking?
hey billy take the car down to cruisngold on 192. they will balance the tires, went there for mine and they have a nice "road force balancer". i would check the wheel real quick to see if it has the hubcentric ring before you go though, its a black plastic ring
You can check by taking the wheel off..you'll see an inner plastic or metal ring on the inner side inside the center hole. Sometimes it pulls off and gets stuck on the hub itself..which is fine, if you put the same style wheel back on. If you still don't know..have someone check for you. You want to mount the wheel with those on, or you can get an imbalance..even if it balances off the car!
