Steering wheel shaking after new wheels/tires
Old Feb 14, 2011 | 11:45 PM
Phyrric's Avatar
Long story short, steering wheel shakes/jiggles with my new wheels/tires Enkei EKM3s 18x8 and tires are Potenza re760 sports 235/40/18 on stock ride height, but the thing is, it does it at random speeds, and random parts of roads, so I was thinking maybe since I have "Sport" tires, it sacrifices some comfort for grip and I'm just feeling more of the road? I tried to take a video when I was driving today, which I just realize is sideways
YouTube - Shaking steering wheel
Old Feb 14, 2011 | 11:46 PM
09PitchBlackSS's Avatar
Did you get your wheels balanced when you put them on?
HB_SS/TC's Avatar
rebalance the tires
Old Feb 14, 2011 | 11:48 PM
08ssedan's Avatar
Originally Posted by HB_SS/TC
rebalance the tires
This. I got my v12s put on this past weekend and my tires need to be rebalanced.
Phyrric's Avatar
Wow I'm so retarded, I told em I was gonna pass on it since I was lowering the car soon but I dont think its happening right away, Am I doing any damage to the car or just a shittier ride?
Old Feb 14, 2011 | 11:53 PM
CleanCut's Avatar
(re) balance your tires /thread
Old Feb 15, 2011 | 12:00 AM
08ssedan's Avatar
No damage being done, just a pain in the ass
ronn's Avatar
need to be a bit more specific. Does the wheel shimmy back and forth while holding on...or are you just feeling the vibrations through the steering wheel? A shimmy is an imbalance for sure..could be tires or could be wheels themselves. Either way, you should be able to balance that out....even with wider rims and tires. I'm gonna rule out anything else (suspension) because this all started with the new stuff. The stock set up (my car) is smooth as silk...so should your new set up.
One other thing..make sure the wheel is HUB CENTERED..not just bolted up. Wheels should come with hub ring for hub centric mounting. Otherwise you could get imbalance ON THE CAR (although balanced OFF the car).
Old Feb 15, 2011 | 12:01 AM
Phyrric's Avatar
It's deff the tire balance that I need, there's no vibration, the wheel just jiggles back and forth slightly
Old Feb 15, 2011 | 12:11 AM
ronn's Avatar
Ok..how about the hub rings? Did they provide them?
Here is a link to order them for our car and Enkie wheels:
Hubcentric Rings for a 2009, Chevrolet Cobalt SS with Enkei wheels - JustForWheels.com
Old Feb 15, 2011 | 12:32 AM
AyrtonSenna's Avatar
Unbalanced tires may also lead to make the tires wear off the wrong way
Old Feb 15, 2011 | 01:00 AM
09sscalicobalt's Avatar
its either the balance or you need an alignment
Old Feb 15, 2011 | 01:01 AM
myfakeevo's Avatar
you should always rebalance your tires if you changed them
Old Feb 15, 2011 | 01:07 AM
yup this is true i only get alignment after i lower the car or about once a year
Old Feb 15, 2011 | 01:09 AM
DiabeticKripple's Avatar
definatly need to balance
Old Feb 15, 2011 | 01:13 AM
arman14's Avatar
Did you get hubcentric rings?
Old Feb 15, 2011 | 01:21 AM
Phyrric's Avatar
I have no idea, I never took the wheels out of the box, all I know is I got wheels, and then they said they found locking lugnuts in the box, I don't think they'd mention finding hubcentric rings to any normal customer though haha
Old Feb 15, 2011 | 01:30 AM
arman14's Avatar
Take a wheel off and see by yourself.
I had the same issue back when I had my cobalt,I just put some hubcentric rings on and the shaking was gone
Does the steering wheel also shake when breaking?
Old Feb 15, 2011 | 01:32 AM
08ShowbaltLS's Avatar
hey billy take the car down to cruisngold on 192. they will balance the tires, went there for mine and they have a nice "road force balancer". i would check the wheel real quick to see if it has the hubcentric ring before you go though, its a black plastic ring
Old Feb 15, 2011 | 01:36 AM
ronn's Avatar
I have no idea, I never took the wheels out of the box, all I know is I got wheels, and then they said they found locking lugnuts in the box, I don't think they'd mention finding hun centric rings to any normal customer though haha
You can check by taking the wheel off..you'll see an inner plastic or metal ring on the inner side inside the center hole. Sometimes it pulls off and gets stuck on the hub itself..which is fine, if you put the same style wheel back on. If you still don't know..have someone check for you. You want to mount the wheel with those on, or you can get an imbalance..even if it balances off the car!
Old Feb 15, 2011 | 11:03 AM
myfakeevo's Avatar
was it necessary to have your camera sideways and playing shitty music?
Old Feb 15, 2011 | 06:39 PM
munit06SS's Avatar
was it necessary to make a useless post?
it sounds like a balance issue. Like everyone said already get them rebalanced and check for the hubcentric rings.
Old Feb 15, 2011 | 07:20 PM
myfakeevo's Avatar
yes. im troollllinnnn
Old Feb 15, 2011 | 08:24 PM
munit06SS's Avatar
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
