think i made a bad choice with my tires
Old Apr 14, 2009 | 10:48 AM
venum_us_2002's Avatar
I was out cruising the past weekend and almost everycar that is saw drop there clutch from a dig would peal out for maybe 1sec and than take off like a bat out of hell. Now if i do this (rev to about 1.5-2k) and even ease it out and give it gas i will just sit there and spin but no noise comes from my tires like im pealing out. They just spin. Is it because my tires suck? it is also 41 degrees out lol.
These are my tires with tons of tread left
http://www.tirerack.com/tires/tires....nSpeedRating=V
Old Apr 14, 2009 | 10:50 AM
shawn672's Avatar
those tires are pretty good - you're probably not launching as hard as them
burnouts are lame in a fwd anyways
roadrage06's Avatar
same thing happened to me..............hint: it's not your tires. I finally used my head and said to msyelf "no noise, no tire tracks, and no smoke............it's not the tires".
Your clutch is slipping, garaunteed.
Old Apr 14, 2009 | 10:52 AM
im not trying to do a burnout...lol...
Im trying to actually launch good from a dig
good thing im talking with NGA about a new clutch. I hope that is the problem because otherwise i have no idea. But when i go WOT in 2nd all the way to redline it doesnt slip
Last edited by venum_us_2002; Apr 14, 2009 at 10:52 AM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 10:54 AM
roadrage06's Avatar
That's because the clutch isn't slipping because it's worn out, it's slipping because it doesn't have the holding power.
I bet when you do a second gear drop you can hear it stuttering.
Old Apr 14, 2009 | 10:55 AM
Ruchus's Avatar
Clutch clutch clutch... Time for an upgrade.
Old Apr 14, 2009 | 11:06 AM
When i 1-2 shift without taking my foot completely off the clutch it will slip like mad even my 2-3 shifts and it never used to do this when i was stock or even gm stage 2. So guess thats my next mod for the money pit
Old Apr 14, 2009 | 11:22 AM
shabodah's Avatar
Of topic, but, anybody have good ideas for trying to keep tire smoke out of the cabin?
Old Apr 14, 2009 | 11:23 AM
Bumpin Balt's Avatar
Those tires have a tread wear rating of 400. That means the rubber is REALLY hard and not very grippy. The stock tires are rated a 200, so yeah, you chose bad tires for a performance car.
Ummm, don't do a burnout and close your windows? lol
Last edited by Bumpin Balt; Apr 14, 2009 at 11:23 AM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 11:24 AM
with my mods will i be fine with a spec stage 2+ clutch?
Old Apr 14, 2009 | 11:28 AM
widowedeight's Avatar
NOT TRUE the tires i just got have a tread rating of 400 (ultra high performance all season radials.......) and they have AMAZING TRACTION and i'm not stock
should be
Last edited by widowedeight; Apr 14, 2009 at 11:28 AM. Reason: Automerged Doublepost
Old Apr 14, 2009 | 11:29 AM
roadrage06's Avatar
don't know. I had the Stage 1 clutch in, didn't work at all.
The reason I know that it's your clutch is cuz mine is in the shop right now. I broke an axle. I thought it was my tranny so I also had them take it out and look at the clutch and transmission. They told me the clutch is not holding and something with the flywheel. So I'm getting a Centerline DFX Clutch and Flywheel -- rated at 450hp/450lb-ft tq. I should be getting it back either today or tomorrow.
what i got...... amazing so far
Old Apr 14, 2009 | 11:42 AM
Ruchus's Avatar
https://www.cobaltss.net/forums/parts-66/fs-spec-clutch-new-flywheel-more-165241/
theres a clutch for sale
Old Apr 14, 2009 | 12:32 PM
thehov's Avatar
Yup everyone sounds about right, clutch........ Although those tires arent the greatest but they should still be fine.
Old Apr 16, 2009 | 11:06 AM
aterminatorz's Avatar
If you don't hear your tires, they are not spinning. Your clutch must be slipping if the rpms are increasing and you are not moving or spinning the tires. Those are not summer performance tires, they look like all-seasons. The tires are the least of your problems though...
Old Apr 16, 2009 | 11:28 AM
turbaltss's Avatar
[QUOTE=widowedeight;3730494]NOT TRUE the tires i just got have a tread rating of 400 (ultra high performance all season radials.......) and they have AMAZING TRACTION and i'm not stock
Another thing those are all season tires not summer only the guys pulling harder than you are likely on summer only tires (true high perfomance tires).
bigdeertz
Nov 17, 2016 09:41 AM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
jas09ss
Sep 26, 2015 01:06 PM
