tire rotation
tire rotation
ok guys i still run the pirelli rossos on my ss and i had rotated them like the manual said. two rear tires crossed into front, front two straight back. right after doing that i punctured one of my sidewalls on the front right tire, which was just the left rear. i bought a new tire and replaced it back to the same spot. now it pulls like a mother to the right. are these tires directional or what? i put the tire on the same way the other one was, so its on the way its supposed to be
Shouldn't be directional. If it was, it would have an arrow pointing in the direction it should be on the sidewall.
Possibly it's the new tread? It grips harder on one side, so it feels like it's pulling to that side...
with that low a profile tire, sure it can cause a pull, as long as you didnt hit anything, you shouldnt need an alignment. easy way to tell is rotate the tires across. If it pulls left, you know its a tire issue
thats the latest peice of advise i was given, i am going to try it tomorrow. just now i checked all tires pressure wise and made sure they were all at 32 lbs each exactly. some were off a few pounds but nothing major, we shall see on the ride home from work. if its not fixed tomorrow i will throw it on the other side. outside of that i guess i will have the alignment checked, but it wasnt like this before the tire swap so i dont think thats what it is. someone made a comment about the balance, usually you get some vibration with a bad balance and i have zero. rides smooth as ever, just pulls, and harder with more acceleration
If you have 15k on the tires and you just put one brand new tire on the car it is going to pull like crazy. You need to get another tire to put on the other side so the tread matches. 15K on the stock Pirellis and you have used more then half the tread already. The stock Pirelli's typically only last 20K - 30K miles if you drive easy and less if you drive agressively.
First off, don't buy Rosso's when tires that are just as good cost far less. Lesson learned.
Second, get them rebalanced. I had the same problem and they were out of balance. If you get a wobble at low or high speeds they are definitely out of balance.
i dont have wobble or vibration like i said, so it should not be a balance issue. also, the tires with 15k on them are not even close to 50 percent worn. if you only got 20k out of any tire something was wrong. as far as not buying a rosso i am not about to run around with different tires on ****, lol. i spent the extra, which did suck, but in the spring i plan on getting a set of wheels tires anyway
Tires that are outta balance shouldnt cause the car to pull.If it was out of balance you would get a vibration at highway speeds.Your best bet would be to replace the tire on the other side.
thank you, like i have been saying there is no vibration. i am not replacing the other tire because i am going to try to get a set of wheels and tires in the summer, what i may do is stick it on the rear. should make a big difference in the pulling
i agree, stick it on the rear, as stated above, new tire, larger diameter, old tire smaller diameter. Take small wheels of differant diameters, and spin them at the same speed, i promise the taller wheel will move further. Causing a pull.
The Pirelli's are UTQG 200 tires which equates to a 20K mile tire. If you are lucky and drive easy you maybe able to get 30K or so out of tires but no more. I have to replace my tires and I have 30K on them right now. They have never been abused, never been spun except for a few chirps and never been driven at high speeds. On my old car I didn't change the tires until 100K miles. So don't tell me there is anything wrong with my driving. Just because you can't tell by looking, trust me the tires are probably about 50% worn. Now if you wish to continue driving with one new tire and 3 worn tires then you are the one damaging your car and damaging your other 3 tires.
Look I am trying to help you and if you are not smart enough to see that then I guess I am wasting my time. Let's try this again:
While the tires aren't directional, they ARE assymetrical........meaning they have an inside and an outside, and they must be mounted accordingly. Having one mounted wrong could possibly cause a pull to one side.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
