Tires for 17's
Old Aug 27, 2007 | 02:56 PM
shawn672's Avatar
Tires for 17's
Got the Cobalt LT w/ Sports Pack.
Window shopping for replacement tires, what size are these?
Is there any one manufacturer that stands out amongs the rest? Looking for performance tires
Old Aug 27, 2007 | 03:09 PM
FinalBreath's Avatar
I have 225/45/zr17. tires are a bit wider than stock.
Old Aug 27, 2007 | 03:29 PM
shawn672's Avatar
how do they fit on the stock rims? i dont want anything bulging out, but i could use a little more traction
edit: when i did a search for tires it lists them like this: "225/70R15" "225/30R20"
im lost
Old Aug 31, 2007 | 09:35 PM
Dispute's Avatar
And as far as reading the tire sizes the first numbers are how wide the tread is in mm, the second number is the aspect ratio, which determines how tall the sidewall is and the last number is the rim diameter. The R between the aspect ratio and rim size means radial, when finalbreath wrote zr the z was the speed rating. I hope that helps.
Oyea back to your question, if you want a performance tire you get what you pay for most of the time. Goodyear Eagle f1 all season is one i like, but your best bet is to go online or to a tire store with your size and see whats out there in your price range
Old Aug 31, 2007 | 09:48 PM
shawn672's Avatar
awesome. thx for the help and the lesson. helps explain a lot
Old Aug 31, 2007 | 11:34 PM
jschatte's Avatar
the lt comes with 16" rims not 17"
Old Sep 1, 2007 | 12:27 AM
Archie's Avatar
^^^^Was just gonna say that.
The widest you should go on 7" wide wheels (factory), would be 225/45R16. On a 7.5" wheel, you can put on 235/45R16, or 235/50R16. The second being a little too tall.
And on the 225/45ZR17, the Z in the tire size doesn't really tell you the exact speed rating. It is just informing the mechanic, that the tire can only be repaired once, and that that the tire is rated at 168mph or higher. To actually tell the exact speed rating, you need to look at the service description usually off to the right of the size. That will have a 94W, 97Y, or 93(Y). The Load Index (94,etc) being different for each tire. But the speed ratings are for 168, 186, and 186+ respectively. Just so you know.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
