UniDirectional tire... which way?
Old Mar 13, 2008 | 08:59 PM
roadrage06's Avatar
I have a set of MKW M71 Gun Metal Black wheels and Goodyear Eagle F1 GS-D3 225/40ZR18XL on order from BigWheels.net
When they get here I'm gonna need the answer to the following question:
They are a unidirectional tread, which way should the "v" be facing if looking at it from the front of the car? ^ or v
Thanks in advance.
Old Mar 13, 2008 | 09:01 PM
Super_SS's Avatar
just like u have it in the picture...that is the left side u have pictured..it will tell u on the sidewall which side the tire goes on and which way is forward
LaserBlue07SS's Avatar
There should be a marking on the side wall that says direction of rotation. the tread pattern will look like a V tho to answer your question.
Sunburst_SS's Avatar
there will be an arrow on the sidewall telling you which way they should be mounted, but V
Old Mar 13, 2008 | 09:02 PM
roadrage06's Avatar
Figures it'd be something easy. I had no idea it said that on the side wall.
Old Mar 13, 2008 | 09:09 PM
maverick0716's Avatar
Just for the record, "uni-directional" means that the tire can be mounted either way. Those tires are "directional". Nice wheel choice by the way.....I have the M72s on mine
Old Mar 13, 2008 | 09:15 PM
Red2.4SS's Avatar
uni = one
"Unidirectional" tires are designed for a side specific position, either the right side of the left side and are unidierectionally designed to roll and perform in a given position on the vehicle. If installed in the wrong position the tire will not perform its intended function. However, no damage or premature wear to the tires will result. The tire should be dismounted and remounted to roll in the proper direction and on the proper side of the vehicle.
asymmetrical tires can go any which way.
Old Mar 14, 2008 | 02:08 AM
Originally Posted by Red2.4SS
uni = one
You're right, I got mixed up on the uni-directional, lol. Asymmetrical can roll either way, but must still be mounted a certain way as there is an inside and an outside of the tread pattern.
Old Mar 22, 2008 | 03:02 PM
roadrage06's Avatar
Just got them all in today! But go figure it decided to F*%$@ snow! Weather should be good by Monday, then they go on.
Josh-SS
Wheels and Tires
Mar 24, 2013 04:07 PM
breds2k
Feb 25, 2012 03:38 PM
efactor
Wheels and Tires
Feb 9, 2011 05:39 PM
EcotecAddict
Wheels and Tires
Sep 27, 2009 10:51 PM
mrphotoman
Jul 21, 2009 06:56 AM
