What offset for 18"x9"'s?
Old Mar 6, 2011 | 10:26 PM
Bumpin Balt's Avatar
I'm probably going to be ordering some custom drilled and offset 18x9's in the near future. I'm just trying to decide on which offset. I would like to go with +38, but that may be a bit too aggressive considering I plan on running 255/35/18 Nitto Invo's (They run narrow. Probably narrower than some 245's). I don't have any plans to go any lower than my current setup, but that could change, since I change my mind more often than my underwear!
If you have 9" wide wheels (or 9.5" for that matter), please post your offset, tire size and how much clearance you have between your struts/springs. Pics would be awesome too!
These aren't the wheels I'm getting, but they are 18x9's with 255/35/18 Invo's.
Old Mar 7, 2011 | 03:03 AM
I know SOMEONE has 9" wide wheels. Any input would be appreciated.
Old Mar 7, 2011 | 03:27 AM
Ting-ting's Avatar
blazin is 9inches....wow so gay lol
Old Mar 7, 2011 | 03:36 AM
revolution607@yahoo.'s Avatar
Old Mar 7, 2011 | 03:40 AM
lolz. Would 9.5's with +40 clear the front struts and rear inner fender well? 9'5's would give my spokes a little more Concave and the tires a little more stretch.
Old Mar 7, 2011 | 11:38 AM
^^^Bump for input.
Old Mar 7, 2011 | 12:33 PM
jboogie's Avatar
I'm pretty sure a 9.5 +40 would hit the strut. Maybe this will help ----> https://www.cobaltss.net/forums/auto...rrived-242175/
Old Mar 7, 2011 | 01:34 PM
I guess I'd better stick to 9's. Do you think 9's with +38 would work? That would put my wheels 8mm closer to the struts than yours are.
Old Mar 7, 2011 | 09:40 PM
jboogie's Avatar
I'll get a better measurement when I get a chance you should be fine with that. Just very camber limited up front but enough to get you within normal spec. Wish I had access to a drive on lift.
Old Mar 7, 2011 | 10:49 PM
shadowfaxss's Avatar
Try this.....worked during my 7 month search for 19inch wheels for our BMW X3
Wheel Offset Calculator
Old Mar 7, 2011 | 11:15 PM
That will save A LOT of head scratching! lol. Thanks!
Old Mar 19, 2011 | 10:45 AM
CavCrzy's Avatar
Feeling like an idiot here........but I just got a good deal on some Milli Miglia EV-R,18x9 wheels for my SS. They came with brand new Goodyear Eagle F1 225/35/18 tires. Am I looking at any issues, or need anything additional to mount these? I'm not clear on offsets, if needed, so please excuse the ignorance. Just want to make sure I am not setting myself up for an unsafe situation here. Thanks for any words of wisdom!
Old Mar 19, 2011 | 11:06 AM
mongorat427's Avatar
Check my sig. I went with 17x9 for my drag tires at 38mm offset. if your AUTOX or road racing you might want the offset another 1/2 to the outside. Ill post up some pics later.
Old Mar 19, 2011 | 11:15 AM
CavCrzy's Avatar
Thanks! I'm just going to be having them for daily DD. I got 6 rims in the deal, so I will have 2 for slicks if I ever get the car to the track. What is needed for the offset? Is this something they can do at a tire shop? Sorry for being ignorant on this subject.
2K5SS/SC?
Wheels and Tires
Jul 16, 2006 06:24 PM
slowbalt
Wheels and Tires
Jul 5, 2006 12:46 AM
hardtocope
Wheels and Tires
Nov 1, 2005 12:33 AM
wikkymaster
May 30, 2005 02:41 PM
