Fifth injector kit
Fifth injector kit
I noticed your 5th injector kit is now on the market. My question is would a new fuel pump like ur aeromotive stealth pump be necessary for this kit or can we just run the stock fuel pump
Originally posted by Matt from ZZP in that locked thread
"If you are running our fuel pump lobe intake cam, then you can already support E85 on a typical 450whp upgraded turbo setup without this kit. If you run this kit instead of the larger pump lobe, then you can stick with the factory in-tank pump and support similar power levels. If you are going past 500whp on E85, then you want the pump lobe, 5th injector, and Stealth pump."
Sl0wbaltSS
Nov 21, 2018 11:11 PM
