ZZ Performance ZZ Performance is a proud Supporting Vendor
Speed Density conversion?
Old Nov 28, 2009 | 03:13 AM
Shea561's Avatar
Worth the wild developing? Figured you are the go to guys for Ecotec work and could make it happen if the demand and need is there. Something that may be worth looking into.....
Old Nov 28, 2009 | 03:16 AM
~Mike~'s Avatar
? what is speed density conversion?
Old Nov 28, 2009 | 03:37 AM
Shea561's Avatar
Getting rid of MAF and using a speed density set-up. Its another method of measuring the amount of incoming air. Many advantages to this. Weather its worth the time to develop for the ecotec community I guess only time will tell.....if someone steps up and does it.
Old Nov 28, 2009 | 03:52 AM
glen229's Avatar
alot of people have done this
Old Nov 28, 2009 | 04:31 AM
hungryhip-ccp's Avatar
i have been kicking this around.... lots of hrs tuning involved us turbo guys cant hold a tune for more than a cpl months then the ltft have gone to **** as well as PE AFR, and it needs an hr of tuning to get the maf back on track... then the next day weather changes back and your old tune runs perfect again... so frustrating sometimes not knowing is it gonna run 12.0 afr today or 11.5 like i command.
i here SD tuning will help greatly.
Old Nov 28, 2009 | 04:39 PM
Shea561's Avatar
On cobalts?
I'm sure if enough people would understand what you do and enough interest was built it could get somewhere.
Old Nov 28, 2009 | 07:08 PM
Red05SS/SC's Avatar
streetdreamz did a great write up in the tuning section on how to switch to a 3bar SD tune. If you are running strictly MAF on your tune and it's dialed in then when your in open loop it shouldn't matter what the conditions are outside. A MAF measures roughly the density of the air so it compensates for barometric pressure and other such things that would change values in the tune.
Old Dec 2, 2009 | 03:17 PM
mkriebs's Avatar
It would work on the LSJ, but we don't have enough tables to do it on the LNF yet. Maybe HPT will release them, or maybe Trifecta will. But, I agree, it would be nice to tune with SD.
Old Dec 4, 2009 | 11:28 AM
fredds-turbaltSS's Avatar
Wouldn't putting the MAF in the cold side IC piping fix problems without having to convert to SD tuning?? for the LNF im talking
Old Dec 23, 2009 | 01:16 PM
mkriebs's Avatar
No, it wouldn't. All that is for is for the ricers that want the BOV sound without messing up the MAF sensor.
RaginChopsuey
Oct 27, 2015 01:27 PM
ThoR294
Oct 4, 2015 08:44 PM
Extremespeed
Sep 29, 2015 04:34 AM
ThoR294
Sep 28, 2015 05:31 PM
z28addiction
Sep 28, 2015 12:03 AM
