Anyone got the specs on the o-ring for the GMS1 sensors?
Old 01-27-2012, 01:50 PM
SSlobalt's Avatar
I don't want to have to pay shipping on $5 worth of o-rings. Does anyone know what the ID and OD is on the o-rings for the GMS1 sensor, so I can just pick them up from Grainger? Thanks.
Old 01-27-2012, 02:02 PM
Frogstofall's Avatar
That Wangspeed dood just posted a link to them but I can't find it. If you search posts he has made, you should be able to find it. Or you could PM him.
Old 01-27-2012, 02:11 PM
Wangspeed's Avatar
You want o ring size 202. I think I have a bunch in the garage. They are a little hard to fit, but they are the proper size. Bill @ GM posted ages ago. PM me your addy if you want 2.
Old 01-27-2012, 02:12 PM
SSlobalt's Avatar
Thank you, Wanger! I'll just grab some in town. Thanks for the offer, though. You da man.
Old 01-28-2012, 10:24 AM
ds33gt's Avatar
Just ordered the harnesses and sensors, it doesn't come with o rings?
If not I may hit you up for two wangspeed....
Old 01-28-2012, 12:38 PM
Wangspeed's Avatar
It comes with o rings. I forget how, but I nicked one of mine, so I picked up a packet of spares. BTW - you'll need to use small picks to get them on/off without damaging them, and you should put a very light layer of silicon or clean engine oil to get them on, and into the pipe.
Old 01-28-2012, 01:01 PM
etnies's Avatar
there a size 202 same as the injectors orings
Old 01-28-2012, 03:03 PM
SSlobalt's Avatar
The 3 bars come with the green o-rings from CED. You were supposed to order the o-rings that CED sells for this purpose. When you order the adapter plugs like we did, you don't read the GMS1 instructions where it says to replace the o-rings with: O-RING 3 Bar Map Sensor 12626998.
It's a fatter o-ring that replaces the green stock 3 bar o-ring, because the stock 3 bar o-ring is meant for the HHR coldside pipe which, I guess, has a different size of hole in it.
From the instruction pdf:
11. Make sure that the green O-ring from the production MAP sensor
is no longer attached to the mounting surface. Put the
new O-ring on the new TMAP sensor. Both are provided in the
kit. Lubricate O-ring with clean engine oil before installation.
Old 01-28-2012, 03:39 PM
ds33gt's Avatar
Everything I ordered was from CED. I ordered 2 sensors and the harnesses...I had assumed if i needed anything else it would be supplied or resuse stock seals...
I'm not running GM stage 1, just want to be able to accurately tune using HP tuners
Old 01-28-2012, 04:06 PM
ds33gt's Avatar
That really pisses me off...
So i am going to need these...maybe a local dealer will have a couple. Is this a common seal or is it pretty specific to the lnf?
This must be the one then....
O-RING 3 Bar Map Sensor 12626998 - Crate Engine Depot
Old 01-28-2012, 04:15 PM
Wangspeed's Avatar
Good lord. You could order a whole bag full for a few bucks. $3 per ring is kinda crazy. Just make sure it's something that will withstand the oil and temp, like buna-n/nitrile or Viton.
Old 01-28-2012, 05:40 PM
SSlobalt's Avatar
Yeah, that's the ring. You can get them cheap through Grainger, but my Grainger is a pain in the butt. Wanger was kind enough to help me out.
Old 01-28-2012, 09:53 PM
ds33gt's Avatar
I would just order but will need them by Wednesday, so I'm kinda pressed for time.
Looking at the stock sensor, I see no reason why I can't resuse the stock o rings on the 2 bar sensors...
Old 01-28-2012, 10:50 PM
Malaclypse's Avatar
I tore one of the O-rings from my kit while installing it on the sensor.
I think I used a blue O-ring from a 5.3L V8 fuel injector set as a replacement. It was about the same size and worked fine.
Old 01-29-2012, 12:32 AM
SSlobalt's Avatar
I though of that but then wondered why they wouldn't just tell you to remove those and put them on the new sensors. Maybe that will work.
Old 01-30-2012, 09:59 AM
Wangspeed's Avatar
Hooked up ds33gt too. I'm down to 40 or so of these things They are milspec buna-n, aka nitrile. I ordered mine from Mcmaster in a 50 count bag, but they were really repackaged from oringsusa. $13 from Mcmaster for a 50 count bag, or 22 cents each plus shipping from oringsusa.
oringsUSA
http://www.mcmaster.com/nav/enter.asp?partnum=5018T239 (price has gone up since I bought them)
I also tried a few Viton and Fluorosilicone, and neither of those options work. Too stiff. You will break the GMS sensor trying to get them on.
Old 01-30-2012, 01:18 PM
ds33gt's Avatar
Thanks again, wangspeed!!!
If your ever in Naples, FL look me up I'll buy ya a cocktail...
Old 01-30-2012, 09:35 PM
SSlobalt's Avatar
Werd. Same goes for Austin, Wanger!
Old 01-30-2012, 10:53 PM
Wangspeed's Avatar
I miss that city. Went to school there @ UT. Long time ago now though. I bet it's changed a ton since 98 or so
Old 01-31-2012, 07:26 AM
SSlobalt's Avatar
Sure has. I graduated from A&M back in '93, but you're not my enemy anymore. Now, it's Arkansas.
Old 03-06-2012, 12:07 PM
DPveritasGold's Avatar
I'm UT alumni as well! Hookem Horns!
Old 05-13-2013, 01:06 PM
metroplex's Avatar
I probably wouldn't have used Nitrile. I looked at the different O-ring materials and fluorosilicone is probably the best route to go. They all have similar durometer ratings (A70-A75) so one being more "rigid" than the other shouldn't be a problem, just use plenty of lube. The fluorosilicone is also rated to a colder temperature that makes me feel more comfortable. The Buna-N/Nitrile and Viton O-rings don't seem to be rated as low as what the rest of the engine is rated for, but I could be wrong.
I avoided sliding the O-rings over the 3-bar MAP sensors, there is part of the flute that is sharp and could tear into the O-rings if you forced them down. I wrapped the flutes with clear scotch tape so the o-rings would slide right down.
Old 05-14-2013, 08:08 PM
SSlobalt's Avatar
I just smeared mine with motor oil and jammed them on there.
Old 03-01-2017, 10:38 AM
2000Firehawk's Avatar
I know that I'm updating an old thread...
Good deal on these o-rings at Amazon.
Amazon Amazon
It's an 'add-on' item, meaning that it can only be added on to an order & can't be bought
just by itself.
$3.20 for a bag of 100....
100 of these, for what you would pay for just one...
I got my bag of o-rings yesterday, & just installed one on my buggy today.
Perfect fit....
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
maliki778
10-01-2015 07:39 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Anyone got the specs on the o-ring for the GMS1 sensors?
