Anyone got the specs on the o-ring for the GMS1 sensors?
Old Jan 27, 2012 | 01:50 PM
SSlobalt's Avatar
I don't want to have to pay shipping on $5 worth of o-rings. Does anyone know what the ID and OD is on the o-rings for the GMS1 sensor, so I can just pick them up from Grainger? Thanks.
Old Jan 27, 2012 | 02:02 PM
Frogstofall's Avatar
That Wangspeed dood just posted a link to them but I can't find it. If you search posts he has made, you should be able to find it. Or you could PM him.
Old Jan 27, 2012 | 02:11 PM
Wangspeed's Avatar
You want o ring size 202. I think I have a bunch in the garage. They are a little hard to fit, but they are the proper size. Bill @ GM posted ages ago. PM me your addy if you want 2.
Old Jan 27, 2012 | 02:12 PM
SSlobalt's Avatar
Thank you, Wanger! I'll just grab some in town. Thanks for the offer, though. You da man.
Old Jan 28, 2012 | 10:24 AM
ds33gt's Avatar
Just ordered the harnesses and sensors, it doesn't come with o rings?
If not I may hit you up for two wangspeed....
Old Jan 28, 2012 | 12:38 PM
Wangspeed's Avatar
It comes with o rings. I forget how, but I nicked one of mine, so I picked up a packet of spares. BTW - you'll need to use small picks to get them on/off without damaging them, and you should put a very light layer of silicon or clean engine oil to get them on, and into the pipe.
Old Jan 28, 2012 | 01:01 PM
etnies's Avatar
there a size 202 same as the injectors orings
Old Jan 28, 2012 | 03:03 PM
SSlobalt's Avatar
The 3 bars come with the green o-rings from CED. You were supposed to order the o-rings that CED sells for this purpose. When you order the adapter plugs like we did, you don't read the GMS1 instructions where it says to replace the o-rings with: O-RING 3 Bar Map Sensor 12626998.
It's a fatter o-ring that replaces the green stock 3 bar o-ring, because the stock 3 bar o-ring is meant for the HHR coldside pipe which, I guess, has a different size of hole in it.
From the instruction pdf:
11. Make sure that the green O-ring from the production MAP sensor
is no longer attached to the mounting surface. Put the
new O-ring on the new TMAP sensor. Both are provided in the
kit. Lubricate O-ring with clean engine oil before installation.
Old Jan 28, 2012 | 03:39 PM
ds33gt's Avatar
Everything I ordered was from CED. I ordered 2 sensors and the harnesses...I had assumed if i needed anything else it would be supplied or resuse stock seals...
I'm not running GM stage 1, just want to be able to accurately tune using HP tuners
Old Jan 28, 2012 | 04:06 PM
ds33gt's Avatar
That really pisses me off...
So i am going to need these...maybe a local dealer will have a couple. Is this a common seal or is it pretty specific to the lnf?
This must be the one then....
O-RING 3 Bar Map Sensor 12626998 - Crate Engine Depot
Old Jan 28, 2012 | 04:15 PM
Wangspeed's Avatar
Good lord. You could order a whole bag full for a few bucks. $3 per ring is kinda crazy. Just make sure it's something that will withstand the oil and temp, like buna-n/nitrile or Viton.
Old Jan 28, 2012 | 05:40 PM
SSlobalt's Avatar
Yeah, that's the ring. You can get them cheap through Grainger, but my Grainger is a pain in the butt. Wanger was kind enough to help me out.
Old Jan 28, 2012 | 09:53 PM
ds33gt's Avatar
I would just order but will need them by Wednesday, so I'm kinda pressed for time.
Looking at the stock sensor, I see no reason why I can't resuse the stock o rings on the 2 bar sensors...
Old Jan 28, 2012 | 10:50 PM
Malaclypse's Avatar
I tore one of the O-rings from my kit while installing it on the sensor.
I think I used a blue O-ring from a 5.3L V8 fuel injector set as a replacement. It was about the same size and worked fine.
Old Jan 29, 2012 | 12:32 AM
SSlobalt's Avatar
I though of that but then wondered why they wouldn't just tell you to remove those and put them on the new sensors. Maybe that will work.
Old Jan 30, 2012 | 09:59 AM
Wangspeed's Avatar
Hooked up ds33gt too. I'm down to 40 or so of these things They are milspec buna-n, aka nitrile. I ordered mine from Mcmaster in a 50 count bag, but they were really repackaged from oringsusa. $13 from Mcmaster for a 50 count bag, or 22 cents each plus shipping from oringsusa.
oringsUSA
http://www.mcmaster.com/nav/enter.asp?partnum=5018T239 (price has gone up since I bought them)
I also tried a few Viton and Fluorosilicone, and neither of those options work. Too stiff. You will break the GMS sensor trying to get them on.
Old Jan 30, 2012 | 01:18 PM
ds33gt's Avatar
Thanks again, wangspeed!!!
If your ever in Naples, FL look me up I'll buy ya a cocktail...
Old Jan 30, 2012 | 09:35 PM
SSlobalt's Avatar
Werd. Same goes for Austin, Wanger!
Old Jan 30, 2012 | 10:53 PM
Wangspeed's Avatar
I miss that city. Went to school there @ UT. Long time ago now though. I bet it's changed a ton since 98 or so
Old Jan 31, 2012 | 07:26 AM
SSlobalt's Avatar
Sure has. I graduated from A&M back in '93, but you're not my enemy anymore. Now, it's Arkansas.
Old Mar 6, 2012 | 12:07 PM
DPveritasGold's Avatar
I'm UT alumni as well! Hookem Horns!
Old May 13, 2013 | 01:06 PM
metroplex's Avatar
I probably wouldn't have used Nitrile. I looked at the different O-ring materials and fluorosilicone is probably the best route to go. They all have similar durometer ratings (A70-A75) so one being more "rigid" than the other shouldn't be a problem, just use plenty of lube. The fluorosilicone is also rated to a colder temperature that makes me feel more comfortable. The Buna-N/Nitrile and Viton O-rings don't seem to be rated as low as what the rest of the engine is rated for, but I could be wrong.
I avoided sliding the O-rings over the 3-bar MAP sensors, there is part of the flute that is sharp and could tear into the O-rings if you forced them down. I wrapped the flutes with clear scotch tape so the o-rings would slide right down.
Old May 14, 2013 | 08:08 PM
SSlobalt's Avatar
I just smeared mine with motor oil and jammed them on there.
Old Mar 1, 2017 | 10:38 AM
2000Firehawk's Avatar
I know that I'm updating an old thread...
Good deal on these o-rings at Amazon.
Amazon Amazon
It's an 'add-on' item, meaning that it can only be added on to an order & can't be bought
just by itself.
$3.20 for a bag of 100....
100 of these, for what you would pay for just one...
I got my bag of o-rings yesterday, & just installed one on my buggy today.
Perfect fit....
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
maliki778
Oct 1, 2015 07:39 PM
jmelton327
Sep 26, 2015 10:04 PM
