Belt position LSJ SC on a LE5
Old 09-12-2015, 07:56 PM
bobbob160's Avatar
I installed the LSJ supercharger on my LE5 motor. Kept the 5 rib crank, A/C, alternator pulleys; tensioner, idler and SC are 6 rib.
I cut off one rub from the belt. Does the belt work best on the front 5 ribs, leaving the back (engine side) open, or the reverse, leaving the front rib empty.
I had a bad squeal, replaced belt with new, quiet, but starting to squeal again. Currently I have it on the front 5.
Old 09-12-2015, 09:04 PM
Jesse's Avatar
Is it the stock SC pulley size? If not what size is it? Do you have the adjustable tensioner from ZZP or the oversize tensioner pulley?
Old 09-12-2015, 09:08 PM
bobbob160's Avatar
3.1 ZZP Pulley. Everything else added was stock LSJ
Old 09-12-2015, 10:06 PM
Jesse's Avatar
Someone can prove me otherwise but I have seen members with 2.8 pulley on 5 ribs. I think the problem is not enough tension. You could either try the stage 2 belt or the oversized tensioner pulley. The pulley is cheaper at $18. The adjustable tensioner is way too damn expensive at $120 so screw that option. Here's the pulley. It requires some grinding.
Oversized LSJ Tensioner Pulley
And here's the stage 2 belt which was designed for the 3.1" pulley anyway.
Pulleys & Belts
Ecotecftw (09-13-2015)
Old 09-13-2015, 12:34 AM
Ecotecftw's Avatar
Awesome to see another LE5 Supercharged... I'm in the process of getting the parts to do mine. Good question and answer.
Old 09-13-2015, 01:15 PM
bobbob160's Avatar
Still waiting to hear does the belt go in the front of the pulley or back?
Old 09-13-2015, 04:53 PM
chevygirl2006's Avatar
Old 09-15-2015, 03:50 PM
cobalt_sport08's Avatar
I have the stage 2 belt on a 2.9 and the adjustable tensioner. It was a bitch to install, for some reason I couldn't find a belt in between the stock as size and the GM stage 2 hat was 5 rib and double sided
Old 09-15-2015, 06:19 PM
It's actually pretty easy.
Old 09-15-2015, 11:31 PM
nhanson's Avatar
Just look down at the pullies...not hard to see where it lines up.
I think its towards right side
Supercharged06SS
12-11-2022 04:47 PM
DarrenGC
12-24-2021 01:55 PM
06MetallicBalt
08-17-2021 03:40 PM
justinchinn
10-02-2015 12:18 PM
cw383
09-30-2015 12:41 AM
Quick Reply: Belt position LSJ SC on a LE5
