Belt position LSJ SC on a LE5
Old Sep 12, 2015 | 07:56 PM
bobbob160's Avatar
I installed the LSJ supercharger on my LE5 motor. Kept the 5 rib crank, A/C, alternator pulleys; tensioner, idler and SC are 6 rib.
I cut off one rub from the belt. Does the belt work best on the front 5 ribs, leaving the back (engine side) open, or the reverse, leaving the front rib empty.
I had a bad squeal, replaced belt with new, quiet, but starting to squeal again. Currently I have it on the front 5.
Old Sep 12, 2015 | 09:04 PM
Jesse's Avatar
Is it the stock SC pulley size? If not what size is it? Do you have the adjustable tensioner from ZZP or the oversize tensioner pulley?
Old Sep 12, 2015 | 09:08 PM
bobbob160's Avatar
3.1 ZZP Pulley. Everything else added was stock LSJ
Old Sep 12, 2015 | 10:06 PM
Jesse's Avatar
Someone can prove me otherwise but I have seen members with 2.8 pulley on 5 ribs. I think the problem is not enough tension. You could either try the stage 2 belt or the oversized tensioner pulley. The pulley is cheaper at $18. The adjustable tensioner is way too damn expensive at $120 so screw that option. Here's the pulley. It requires some grinding.
Oversized LSJ Tensioner Pulley
And here's the stage 2 belt which was designed for the 3.1" pulley anyway.
Pulleys & Belts
Old Sep 13, 2015 | 12:34 AM
Ecotecftw's Avatar
Awesome to see another LE5 Supercharged... I'm in the process of getting the parts to do mine. Good question and answer.
Old Sep 13, 2015 | 01:15 PM
bobbob160's Avatar
Still waiting to hear does the belt go in the front of the pulley or back?
Old Sep 13, 2015 | 04:53 PM
chevygirl2006's Avatar
Old Sep 15, 2015 | 03:50 PM
cobalt_sport08's Avatar
I have the stage 2 belt on a 2.9 and the adjustable tensioner. It was a bitch to install, for some reason I couldn't find a belt in between the stock as size and the GM stage 2 hat was 5 rib and double sided
Old Sep 15, 2015 | 06:19 PM
It's actually pretty easy.
Old Sep 15, 2015 | 11:31 PM
nhanson's Avatar
Just look down at the pullies...not hard to see where it lines up.
I think its towards right side
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
