FINALLY an option for us f35 guys. READ!
Old 06-13-2011, 05:21 PM
  #301
Rattlesnake Race Shop
USMCFieldMP's Avatar
Originally Posted by INFE
I run a 4.45 trans from John 4th gear pulls are fun the car burns alittle more gas on the highway, but its not to bad. What's the best part is that this trans has lasted almost a year of beatings and still shifts perfect. My last 4.05 trans lasted 6months with less power....
Yeah, but you're leaving out the part where it was in Paul's car.
Old 06-13-2011, 05:36 PM
  #302
donkeyballs's Avatar
I have the money but i'm still not sure this is the best option.. For 2k and only getting 2 gears and nothing else done to the transmission? Does everyone really think this will hold the power and not blow a hole through the transmission? And is it really gonna be better than ZZp's? I really don't know **** about transmissions so i really don't know what to do haha..
Old 06-13-2011, 05:57 PM
  #303
I'm kind of right here too.
I personally think that the new gears would only be addressing the symptom, not the problem. As I have said a number of times... the reason that 3rd gear strips its teeth, is not sheer power (at lower power levels, at least). Its from Flex. The Input/Output shafts (along with the case) flex under the torque load, separating the gears so that they are only engaged on the tips of the teeth.
Old 06-13-2011, 06:07 PM
  #304
Well my question is how many people have blown the transmission launching or in 1st or 2nd gear? I'm sure wheel hop causes the most damage and i think it will blow just like stock but you will be out a lot more money.
Old 06-13-2011, 06:23 PM
  #305
Wheel hop is an EXTREMELY easy fix though. And AFAIK, not too many people actually blow up transmissions launching or going WOT in 1st or 2nd. I've only ever seen true issues with gears failing in 3rd gear. Synchros failing, etc... that's a whole different ball game. I've had a 2nd gear synchro fail. Still have the trans sitting in my garage actually. Been 4 1/2 years now. Damn.
Old 06-13-2011, 07:02 PM
  #306
TheBaltSS's Avatar
I had a 2nd gear Synchros fail and had it fix by GM and then a 5th gear Synchro go out on me
Old 06-13-2011, 07:45 PM
  #307
What mounts do you have? I have to order some this week thinking about getting them through powell.
Old 06-13-2011, 09:13 PM
  #308
cmiller8006's Avatar
I dont think they are going to just do the two gears and be done. And I have never seen a lsd blow or first and second from power or launching. I believe they will fix the issue with the flexing shafts, which is what zzp does by making all the tolorances tighter. Wheel hop will not blow the tranny. Maybe the axle. And me personally will pay the extra 200 for the bracing just to be safe. I think this is the best option so far, and it has not even been brought to market, but I know it will be tested very well if I do get it. I would test it for them if they need to lol.
Old 06-13-2011, 09:30 PM
  #309
mongorat427's Avatar
Originally Posted by HHRSSouth
Here I'll help you out bud:
car-part.com has 3 2009 HHR SS LNF G85 transmissions
1 is a grade A part with 31k miles $650 (PA.)
2 is $550 (TX)
3 no price listed (TX)
2 in your neck of the woods waiting to be snatched up
Thats alot cheaper then those 4.45 gears seeing as its a straight bolt in and go.
Heh Heh Heh. I bought my 4.45 trans complete for $175 Saab 900 F35 After I tore it down all the scrap was worth $75
Old 06-13-2011, 09:31 PM
  #310
Powell Race Parts's Avatar
this is true except the main shaft goes through the front bell housing before the gears strip...had one lnf still drove okay with the shaft peeking through the front case, dripping oil of course...
Old 06-13-2011, 09:53 PM
  #311
pimpnwink's Avatar
2 is $550 (TX)
Im about to pick up the one in PA lol. The hhr ss trans bolts in no problem right? Cause I was thinking of swapping to a F23 as Im not too sure yet on this shep trans I need to get my car up and running with the turbo stuff anyway first.
Old 06-13-2011, 09:58 PM
  #312
pimpnwink's Avatar
wait so you bought the 900 trans and just swapped guts? How is it holding.
Old 06-13-2011, 10:24 PM
  #313
I run mounts obtained from John Powell. I wouldn't do it any other way.
Wheel hop can/will crack the trans case though. That was a huge issue for a long time, for the SS/SC's. I think that's part of why they increased the thickness of the Trans case with the LNF's.
Old 06-14-2011, 12:58 AM
  #314
Yea I do remember that now. I think the mounts we run help alot, they keep things stiff but allow some movement at the same time. I think the trans case breaks with solid mounts, I would like to see the failures with what mounts were used.
Old 06-14-2011, 08:35 AM
  #315
terry11's Avatar
I understand you guys will have some doubts about this, but all of these topics have been addressed already in previous pages. When John first talked to me he said the evo guys were blaming their 4th gear failures on case flex as well. After he did a set for them they have pushed his gears with tighter tolerances to 600 awhp and they are still holding fine. I would say there is considerably more case flex at 600 horse compared to 400, and he didn't brace their trans at all.
When he took my trans apart the first thing he e mailed me was our "gears" are way too weak for what we are trying to push through them. I'm not completely ruling out case flex as a potential problem, but not near as big of a problem as everyone makes it seem. I trust John and his knowledge on these topics more than anyone. First hand experience rather than hear say.
The gears he is building us will fix our problem completely. I don't think any of us will ever scatter 1 or 2, especially with things like a wot box that take a ton of stress off of those gears during shifts. With all that said i hope you guys can trust that every angle of this has been thought of and if 1 and 2 would have been manufactured as well none of you would have bought this trans mod due to sheer price, and would have still had doubts about it. So right now I think this is out BEST option hands down.
Old 06-15-2011, 09:00 PM
  #316
terry11's Avatar
Do I really have to bump this
Old 06-15-2011, 09:05 PM
  #317
LOL. Well I may be selling one of the quads, so I may have the money sooner than I thought.
Old 06-15-2011, 09:10 PM
  #318
terry11's Avatar
What quads do you have? Riding used to be my life. I'm a 2 wheel guy tho.
Ok so we definitely have 2 at this point. 8 more guys!
Old 06-16-2011, 10:17 PM
  #319
I actually have a yz450, yfz450, and a wolverine 450 awd. Will post a pic tomarrow. Getting rid of the yfz.
Old 06-17-2011, 12:08 AM
  #320
terry11's Avatar
How do you like the yz? I do a lot of woods riding so I have a 250f for that and I just picked up an Rm250 the other week. I missed the old 2 strokers
Old 06-17-2011, 09:12 PM
  #321
The yz is a beast, but believe it or not the yfz beats it pretty bad lol. We do some woods riding and the yz is great, especially if you like hill climbs, a 250 will do it but it is just so fun with the extra power.
Old 06-18-2011, 01:40 AM
  #322
D-mac's Avatar
Any idea what the price point of these units will be?
Old 06-19-2011, 11:45 AM
  #323
terry11's Avatar
The price is posted on the origonal post!
Old 06-19-2011, 06:36 PM
  #324
I just sold my dirt bike and have extra cash now i don't know what to do... ZZp or this?? I don't know if i'm gonna take the car past 450whp if i do i'm gonna have to do the motor decisions haha..
Old 06-19-2011, 07:08 PM
  #325
G11
G11's Avatar
I love the wolverine! It's the best for moab riding! Anyways! I would like to do the trans but don't have those funds at the moment
Quick Reply: FINALLY an option for us f35 guys. READ!
