stock headlight lighting problem
Old 06-05-2008, 03:43 AM
eurochevy's Avatar
so i noticed when i was leaving my buddies house like 20 min ago that my left headlight doesn't work ...well to an extent..because when i go on high beams it turns on..only when its just regular beam that it doesn't come on..so obviously a electrical issue and not the bulb ..any one have any ideas?
Old 06-05-2008, 03:46 AM
ssweeet's Avatar
Check the low beam fuse. There's two separate fuses for both high beam and low beam.
Old 06-05-2008, 03:47 AM
eurochevy's Avatar
what number fuse i'll actually go check it right now..the fuses if they go out haev a line taht goes through the middle on the top saying its out or w/e right
Old 06-05-2008, 03:48 AM
ssweeet's Avatar
I'm not sure, just pull out your manual and look it up in the engine bay fuse box.
Old 06-05-2008, 03:57 AM
eurochevy's Avatar
k i went out and checked..didn't see any thing wrong with it..but weird thing is that i just learned! = when you push the button on the key to unlock the doors...it will come on but once you open the door or manually put on the lights it will not come on..push the button it will come on so like seriously WTF lol
Old 06-05-2008, 04:30 AM
esfkotaro's Avatar
unlock light uses highbeams, not low
at least mine does. never know these days.
Old 06-05-2008, 05:02 AM
Jesse_Chouinard's Avatar
pretty sure its the bulb. 9007 bulbs are dual filament. the low beam filament is probably fried.
Old 06-05-2008, 05:07 AM
Original Hayden Fanatic
REIGN SS's Avatar
Yes, this seems to be very common in the Cobalts, the headlights are dual filament and the low beam one went out. Just go buy a new bulb and you should be golden
Old 06-05-2008, 01:16 PM
eurochevy's Avatar
well they're after market bulbs but i got a spare one sitting ni my room because i had to buy a new set of 2 because some guy hit my headlight and it smashed over night i'll try that out..when it stops raining!!!!!!!!! although that could be for like a week lol
Old 06-05-2008, 05:15 PM
mattmatt's Avatar
i have gone through 3 pairs of lights 30$ 50$ and 90$ what is the deal.. If i get hids would it still burn out
satisfied
10-19-2015 12:35 AM
How to Guide
57
10-15-2015 11:56 AM
camaromanss1992
10-01-2015 10:51 PM
ATOMbomb
09-11-2015 10:48 AM
jthwjde
09-07-2015 09:24 AM
Quick Reply: stock headlight lighting problem
