weird boost issue
Old 04-24-2014, 12:25 AM
c0de7477's Avatar
weird boost issue
okay, so im sure somebody has had similar symptoms, but i just want to be sure and get some feedback with the codes i pulled.
p0102 - MAF sensor circuit low frequency
p0103 - MAF sensor high frequency
p0100 - MAF sensor circuit insufficient activity
and the one that bothers me:
p0234 - turbocharger engine overboost condition
okay, so obviously the MAF codes... clean maf.. check wiring/connection.. i got that.
but the overboost code? could a faulty maf/wiring cause this.
also, my symptoms were odd. Car was driving fine on the highway.. got off the highway, after going from a light it felt a little ''sluggish'' still drove fine, would just make absolutely 0 boost no matter throttle position. then after a couple minutes it was normal again. this happened maybe 10 times. and then the CEL came on.
any input is appreciated. thanks :]
Old 05-15-2014, 11:28 PM
c0de7477's Avatar
bumping this because it's started happening again (haven't really been driving the car much, as I have a beater DD)
only code I don't see anymore is the p0234.
Old 05-15-2014, 11:35 PM
tomj77's Avatar
maf could just be going bad. overboost issue could be caused by maf going bad reading the incorrect amount of air coming into the engine.
Old 05-30-2014, 11:54 PM
c0de7477's Avatar
Bumping because I changed the maf and problem still exists.any help would be appreciated. What do you think next? Map sensors?
Old 05-31-2014, 02:02 AM
c0de7477's Avatar
popped a new code today. p0114. intake air temp sensor intermittent.
05-28-2022 03:47 AM
Sl0wbaltSS
11-21-2018 11:11 PM
Trav3480
10-01-2015 08:17 PM
Tupp
09-30-2015 08:18 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: weird boost issue
