LAP Mechanical Specs
Old Oct 7, 2008 | 03:12 PM
Maven's Avatar
Metric
English
General Data
Engine Type
Inline 4 Cylinder
Displacement
2.2 L
134 CID
RPO
LAP, LE8(E85 Compatible, HHR)
Letter (VIN)
F
Bore
85.992-86.008 mm
3.3855-3.3861 in
Stroke
94.6 mm
3.727 in
Compression Ratio
10.0:1
Balance Shaft
Bearing Clearance
0.030-0.060 mm
0.0012-0.0024 in
Bearing Diameter - Inside - Carrier
20.050-20.063 mm
0.7894-0.7899 in
Bearing Diameter - Outside - Carrier
41.975-41.995 mm
1.6526-1.6534 in
Bearing Journal Diameter
20.000-20.020 mm
0.7874-0.7882 in
Bushing Clearance
0.033-0.102 mm
0.0013-0.0040 in
Bushing Diameter - Inside
36.776-36.825 mm
1.4479-1.4498 in
Bushing Journal Diameter
36.723-36.743 mm
1.4458-1.4466 in
End Play
0.050-0.300 mm
0.0020-0.0118 in
Block
Balance Shaft Bearing Bore Diameter - Carrier
42.000-42.016 mm
1.6535-1.6542 in
Balance Shaft Bushing Bore Diameter
40.763-40.776 mm
1.6048-1.6054 in
Crankshaft Main Bearing Bore Diameter
64.068-64.082 mm
2.5224-2.5229 in
Cylinder Bore Diameter
85.992-86.008 mm
3.3855-3.3861 in
Cylinder Bore Out-of-Round - Maximum
0.010 mm
0.0004 in
Cylinder Bore Taper - Maximum
0.010 mm
0.0004 in
Cylinder Head Deck Surface Flatness - Transverse
0.030 mm
0.0012 in
Cylinder Head Deck Surface Flatness - Longitude
0.050 mm
0.002 in
Cylinder Head Deck Surface Flatness - Overall
0.08 mm
0.0031 in
Camshaft
Camshaft End Play
0.040-0.144 mm
0.0016-0.0057 in
Camshaft Journal Diameter
26.935-26.960 mm
1.0604-1.0614 in
Camshaft Thrust Surface
21.000-21.052 mm
0.8268-0.8252 in
Connecting Rod
Connecting Rod Bearing Clearance
0.029-0.073 mm
0.0011-0.0029 in
Connecting Rod Bore Diameter - Bearing End
52.118-52.134 mm
2.0519-2.05252 in
Connecting Rod Bore Diameter - Pin End
20.007-20.017 mm
0.7877-0.7881 in
Connecting Rod Side Clearance
0.070-0.370 mm
0.0028-0.0146 in
Connecting Rod Straightness - Bend - Maximum
0.021 mm
0.0083 in
Connecting Rod Straightness - Twist - Maximum
0.04 mm
0.0157 in
Crankshaft
Connecting Rod Journal Diameter
49.000-49.014 mm
1.9291-1.9297 in
Crankshaft End Play
0.050-0.380 mm
0.0012-0.0150 in
Crankshaft Main Bearing Clearance
0.031-0.067 mm
0.0012-0.0026 in
Crankshaft Main Journal Diameter
55.994-56.008 mm
2.2045-2.2050 in
Cylinder Head
Overall Height, Minimum
128.9 mm
5.07 in
Surface Flatness - Block Deck - Transverse
0.030 mm
0.0012 in
Surface Flatness - Block Deck - Longitude
0.050 mm
0.002 in
Surface Flatness - Block Deck - Overall
0.1 mm
0.004 in
Valve Guide Bore - Exhaust
6.000-6.012 mm
0.2362-0.2367 in
Valve Guide Bore - Intake
6.000-6.012 mm
0.2362-0.2367 in
Valve Lifter Bore Diameter - Stationary Lash Adjusters
12.013-12.037 mm
0.4730-0.4739 in
Lubrication System
Oil Pressure - Minimum - @1000 RPM
344.75-551.60 kPa
50-80 psi
Oil Capacity
4.8L
5.0 quarts
Piston Rings
Piston Ring End Gap - First Compression Ring
0.20-0.35 mm
0.008-0.014 in
Piston Ring End Gap - Second Compression Ring
0.35-0.55 mm
0.014-0.022 in
Piston Ring End Gap - Oil Control Ring - Rails
0.25-0.75 mm
0.010-0.030 in
Piston Ring to Groove Clearance - First Compression Ring
0.04-0.08 mm
0.0015-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring
0.030-0.069 mm
0.0012-0.0027 in
Piston Ring to Groove Clearance - Oil Control Ring
0.058-0.207 mm
0.0023-0.0081 in
Piston Ring Thickness - Upper First Compression Ring
1.170-1.190 mm
0.0461-0.0469 in
Piston Ring Thickness - Upper Second Compression Ring
1.471-1.490 mm
0.0579-0.0587 in
Piston Ring Thickness - Oil Control Ring - Rail - Maximum
0.473 mm
0.0186 in
Piston Ring Thickness - Oil Control Ring - Spacer
0.929-1.006 mm
0.0366-0.0396 in
Pistons and Pins
Pin - Piston Pin Clearance to Connecting Rod Bore
0.007-0.020 mm
0.0003-0.0008 in
Pin - Piston Pin Clearance to Piston Pin Bore
0.004-0.012 mm
0.0002-0.0005 in
Pin - Piston Pin Diameter
19.997-20.000 mm
0.7873-0.7874 in
Pin - Piston Pin End Play
0.210-1.266 mm
0.0083-0.0498 in
Piston - Piston Diameter - @14.5 mm up
85.967-85.982 mm
3.3845-3.3851 in
Piston - Piston Pin Bore Diameter
20.002-20.007 mm
0.07875-0.7877 in
Piston - Piston Ring Groove Width - Top
1.23-1.25 mm
0.0484-0.0492 in
Piston - Piston Ring Groove Width - Second
1.52-1.54 mm
0.0598-0.0606 in
Piston - Piston Ring Groove Width - Oil Control
2.01-2.03 mm
0.0791-0.0799 in
Piston - Piston To Bore Clearance, without polymer
0.010-0.041 mm
0.0004-0.0016 in
Valve System
Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster
11.986-12.000 mm
0.0005-0.0020 in
Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster
0.013-0.051 mm
3.2210-3.2299 in
Valve Springs - Valve Spring Load - Closed - @32.5 mm
245.0-271.0 N. - Eng Spec.
Valve Springs - Valve Spring Load - Open - @22.5 mm
525.0-575.0 N. - Eng Spec.
Valves - Valve Face Runout - Maximum
0.04 mm
0.0016 in
Valves - Valve Seat Runout - Maximum
0.05 mm
0.0020 in
Valves - Valve Stem Diameter - Intake
5.955-5.970 mm
0.2344-0.2355 in
Valves - Valve Stem Diameter - Exhaust
5.935-5.950 mm
0.2337-0.2343 in
Valves - Valve Stem to Guide Clearance - Intake
0.030-0.057 mm
0.0012-0.0022 in
Valves - Valve Stem to Guide Clearance - Exhaust
0.050-0.077 mm
0.0020-0.0026 in
Š 2008 General Motors Corporation. All rights reserved.
Old Oct 7, 2008 | 03:20 PM
kkanowitz's Avatar
Very nice man. So only the HHR version (LE8) is flex fuel? OR will the LAP be also?
BTW...I nominate first sticky of this section.
Old Oct 7, 2008 | 03:32 PM
umrdyldo's Avatar
Also, with tuning could the LAP or L61 be used with E85?
Old Oct 7, 2008 | 11:08 PM
Maven's Avatar
The LE8 is the flex fuel version of the LAP. Whether or not the Cobalt will get the LE8 has yet to be seen.
Yes, like any engine it could be tuned to run on E85, but it fuel system is not optimised to do so as in the LE8
Old Dec 22, 2008 | 07:16 PM
Cobaltxfe09's Avatar
bump for maven
Old Jan 8, 2009 | 01:10 PM
RedBaseBolt's Avatar
What exactly are the major differences betweent the L61 and LAP?
Any at all or just new code for minor improvements?
Nevemind. I found the thread that infos in...
Last edited by RedBaseBolt; Jan 8, 2009 at 01:10 PM. Reason: Automerged Doublepost
Old Jan 8, 2009 | 01:15 PM
Maven's Avatar
LAP is essentially a whole new 2.2L engine. Think smaller LE5, not just L61 with VVT.
GM tends not to hand out new RPOs for minor upgrades.
Every 2.2L gasoline ECOTEC without VVT from 2000-2009 is called an L61, there have been numerosu small changes and an entirely new block, head, ignition system, multiple fuel system, etc, etc....
Old Jan 8, 2009 | 01:38 PM
damn. and I thought GM changed the name because it used a new head gasket.
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
theamericanautos
Canadian North East
Sep 24, 2015 08:11 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
