Having heck of a time with B&M shifter
Old May 26, 2006 | 05:34 PM
Bob T's Avatar
I took off today to attempt to put a B&M short throw shifter in my 05 SS/SC. So far 3 hours later and many swear words. I cannot get the shift knob off, Have virtually no idea what a couple of the parts that get re-used look like(my instructions are extremely poor quality) I have sat here reading and printing out different threads on "how to" for the shifter knob. I have the cover off and there is a rubber piece on it with nothing under it. After(if I get it off) which pieces do I keep to re-use ? There is no how to with pics on this either. Bummer. My ride is parked outside and will probably be getting sent off to the Chevy dealer to re-install the stocker(if I have not damaged it). Totally frustrated. Ideas anyone ? I could drill and run a screw in if I knew it will not ruin the thing if I have to get it picked up by Chev.Thanks ahead,
Old May 26, 2006 | 05:38 PM
codyss's Avatar
The stock shift knob looks great but is designed by morons.
It is pressed on so you either need to pull on it really hard or drill a hole tap it a nd press it off by screwing a bolt into the tapped hole.
Old May 26, 2006 | 05:39 PM
GSoccer24's Avatar
take the silver plastic piece off the top of the shift knob that has the gear pattern on it and remove the allen bolt underneath. take a small flathead and stick it up under the shiftknob, lay the body of the shifter assembly on the floor and put your foot on it, then bang the screwdriver with a hammer a few times, the knob should come off. you are going to re-use the bushing for the reverse pivot and the weird thing that surrounds the main ball pivot of the shift knob. that's pretty much all i can remember off the top of my head.
Old May 26, 2006 | 05:54 PM
Bob T's Avatar
Knob Off, check
Got the knob off, Now I finally have the boot off too. What goes next ? What do I save / what do I discard(so to speak)
Thanks
Old May 26, 2006 | 06:09 PM
mattyfinch's Avatar
the instructions are rather detailed minus the removing the stock knob issue, too k 2 hours, and throwing it at the ground about 30 times to get it off
Old May 26, 2006 | 06:46 PM
Bob T's Avatar
Taking for quick test drive. I marked the cables as written . they do match up , but not running the shifting is extremely snug(yes I greased it up too).
Back in 10 minutes.
Old May 26, 2006 | 07:21 PM
Bob T's Avatar
Done, Thanks for the help,
Thanks both for the help on the thread and the PM's I got it all straightened out.
I tell you, This place is just plain awesome(using an old word but fitting for my age group)
Thanks all and thanks CobaltSS.net .
Time for a cruise up the MINN. River ......Bye
Old May 26, 2006 | 07:29 PM
05YELLOWSS's Avatar
How about a how to with pictures, that would be sweet, still gotta put mine on, but I won't be home for another month or so, if you guys want to wait I will do it, if not, somebody do this so I don't have a hell of a time with it...
Old Jul 6, 2006 | 02:54 PM
arsenal21's Avatar
Back in 10 minutes.
Can you explain where you mark the cables and how they get realigned?
I'm gonna install my B&M after work today. I've only glimpsed at the instructions.
Old Jul 6, 2006 | 02:56 PM
DWK5150's Avatar
You mark them where on the end of the clips where the cable goes into them.
Old Jul 6, 2006 | 02:59 PM
arsenal21's Avatar
Thanks.
Old Jul 6, 2006 | 03:00 PM
DWK5150's Avatar
Just remember which cable goes where
Old Jul 6, 2006 | 03:02 PM
05YELLOWSS's Avatar
Just did mine yesterday, not too hard..took about 20 minutes actually...shifts are amazing...so nice
Old Jul 6, 2006 | 03:05 PM
arsenal21's Avatar
Only 20 minutes how so fast?
Old Jul 6, 2006 | 07:19 PM
Fayzer's Avatar
hows it workin out for you? mines on order, really want to see pics on how it looks and whatnot.... thanks for the tips in here, ill be installin mine hopefully next week (if it comes by then)
Old Jul 6, 2006 | 07:35 PM
ggarcia86's Avatar
is shifting effort greatly increased? i had a b & m short shifter on my maxima and its difficult to get it into 1st gear and reverse, i usually have to double clutch it to get it into gear. after that I have been reluctent to get one for the cobalt
Old Jul 6, 2006 | 07:49 PM
uthinkimodd's Avatar
your linkage may have just been off a bit on your maxima, it should shift smoothly.
Builttss
Oct 4, 2015 10:21 AM
Dylan Johnson
Sep 30, 2015 08:57 AM
Extremespeed
Sep 29, 2015 04:34 AM
roth
Sep 26, 2015 12:16 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
