Oil Capacity
Old Jul 5, 2005 | 10:43 AM
wbrault's Avatar
Oil Capacity
I think this was discussed already but I can't find the thread. How much oil does the cobalt take. I checked the manual but I thought I read something somewhere that the manual was wrong.
I have a base cobalt... is the oil 5, 6 or 6.5 quarts???
Thanks!
Old Jul 5, 2005 | 10:56 AM
2K2CamaroSS's Avatar
On my 2.0 it took 6qts with filter change
Old Jul 6, 2005 | 04:55 PM
Funky Cricket's Avatar
mine took 5.5 quarts. full up on the dip stick.
i have a 2.2 base sedan.
Old Jul 6, 2005 | 04:59 PM
wbrault's Avatar
mine took 6 2.2 base
Old Jul 6, 2005 | 07:00 PM
Maven's Avatar
both the L61 and LE5 take 5.0 quarts of oil. putting more in to make the dipstick read full is a waste of oil and also provides for the possibility of aerating your oil(not a good thing) under aggresive conditions.
Put 5 quarts in it. start the car let it run for a minute, shut it off and let it sit for 3 minutes, after 3 mins. read your oil level on the dipstick....regardless of where it is that is full. just keep a mental note. Dipsticks just give a general reading, they arent precision measuring devices, this combined with the various production variances involved with the metal stick itself, its plastic handle the metal tube, its sealing surface, the o-ring, the block's dipstick opening, oil pan thickness variation, amount of oil held in head and oil passages, amount of oil retained in filter, if you look at 10 dipstick all 10 may read differently even with crankcase filled with same volume of oil.
Old Jul 6, 2005 | 08:39 PM
wbrault's Avatar
Thumbs up
Originally Posted by Maven
both the L61 an LSJ take 5.0 quarts of oil. putting more in to make the dipstick read full is a waste of oil and also provides for the possibility of aerating your oil(not a good thing) under aggresive conditions.
thanks for that info!
Old Jul 7, 2005 | 07:34 AM
then again. i just can't have my dipstick read half a quart low... just doesn't feel right.
Old Jul 7, 2005 | 10:37 AM
If you only put in 5 quarts it doesn't even read on the dip stick.
No wonder I never take it to the dealer, HAHA
Old Jul 7, 2005 | 11:12 AM
Maven's Avatar
All I have to say is that every application of the ECotec from 2002 til now including the Alero, Cavalier, Grand Am, Sunfire, Cobalt, Malibu, andG6 ALL HAVE USED 5 qts PER GM SPECS if you choose to overfill it and waste oil because you cant understand that a dipstick isnt a precision measuring device and the Serivce Manual is the proper information more power to ya'.
Old Jul 7, 2005 | 10:18 PM
BJC's Avatar
BJC
But doesn't the Cobalt have a stronger (and since different, possibly larger) oil pan, than the one in those cars you mentioned?
Old Jul 8, 2005 | 11:07 AM
Maven's Avatar
Yes there is more than one oil pan for the two engines and across all the different vehicle platforms, but they all use 5 quarts....except the mighty Supercharged LSJ because of its additional oil cooler.
Old Jul 9, 2005 | 01:51 PM
ninja44's Avatar
So the CSS takes more than 5 quarts? A little confused with your recommendations here
Old Jul 9, 2005 | 05:37 PM
Maven's Avatar
Sorry Ninja.I get a little flustered from time to time when everyone jumps up and down and hollers this and that before they even read there owners manual.
The L61 2.2L takes 5.0 qts oil in all applications 2002-current
The LSJ 2.0L Supercharged takes 6.0 qts in both applications(SS/sc and Redline)
Old Jul 9, 2005 | 05:40 PM
Maven's Avatar
The question was asking for the capacity on the base car(L61) and I didnt notice 2k2CamaroSS had an SS/sc and thats what he was posting about,I also had a typo in one of my first post so that started the confusion(LE5 vs. LSJ)........and there have been other threads and even posts in this one with people claiming anywhere from 4.5 to 6.0 qts wasproper.
Old Jul 9, 2005 | 10:37 PM
ninja44's Avatar
Just did my first oil change at 1000 km and sure enough it took 6 1 quart bottles of Mobil 1
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
