Engine bay cleaning
Old Mar 8, 2007 | 06:45 PM
Evilfrog's Avatar
Engine bay cleaning
Is it safe to spary our engine bays? After having an opti spark i've been worried about spraying ours.
Old Mar 8, 2007 | 09:41 PM
06 pursuit gt's Avatar
its absolutely ok to i do all day i am a detailer at a gm dealership and i have never had any problems. but...you should try to stay away from the plugs and the fuse box. when its cold outside and you bring your car in to wash it water gets into ther and freezes jus a heads up!
Old Mar 8, 2007 | 09:45 PM
My06Coby's Avatar
Of course you can, if you have a 2.4 or 2.2 and a CAI or SRI on it make sure to cover it up appropriatly
Old Mar 8, 2007 | 10:11 PM
BooSSted's Avatar
What products do you guys use to clean your engine bays? What your best method of application?
Old Mar 8, 2007 | 10:45 PM
saunders1986's Avatar
search!!!
Tofu's Avatar
Engine Cleaning
1. Make sure engine is warm, but not hot. Cold engines are harder to remove grease and oil from.
** Check the directions on the engine cleaner/degreaser you are using, though. Some specifically say to clean the engine when cold only. **
2. Cover your distributor (if you do not know what or where it is, get a manual for your car), alternator and fuse box. Most electronics under your hood are adequately sealed for rain water splashing up on them, but high pressure water is another story.
3. Spray Greased Lightning's Orange Blast (my preferred engine degreaser) liberally all over your engine and engine bay. Let it sit for about 5 minutes. If your engine is really dirty, then after the 5 minutes, spray it down again and wait an additional 5 minutes.
4. Spray the engine and engine bay with high pressure rinse water - but even though your distributor may be covered, still use lower pressure around it to be on the safe side.
5. Any remaining grime, spray again with Orange Blast, and use a stiff brush if needed. Rinse again.
6. Remove the plastic coverings and start the engine. Let it run until it is dry. You will have to dry the painted surfaces in the engine bay and the underside of the hood with a towel.
7. Dress any hoses, etc. you want with rubber/vinyl dressing.
Old Mar 8, 2007 | 10:49 PM
BlackSS05's Avatar
^ sounds like exactly what we do at the stealership.
Old Mar 8, 2007 | 10:53 PM
tREBs's Avatar
Originally Posted by Tofu
Engine Cleaning
what do u use to cover the distributor, alternator... etc..??
Old Mar 8, 2007 | 11:10 PM
Tofu's Avatar
I usually use a terry cloth or two. The most important thing it to be liberal with the water...in all honesty the chances of ruining something even without any cover is pretty slim....but I always do it as a precaution.
Old Mar 8, 2007 | 11:14 PM
ChrisAult2004's Avatar
I work at Dave Arbogast in Troy, OH, we just soak the entire bay and underside of the hood in an all purpose degreaser and spray the **** outta it, then use tire shine to dress everything.
Old Mar 8, 2007 | 11:15 PM
halfj99's Avatar
"simple green" is the ****
Old Mar 8, 2007 | 11:20 PM
tREBs's Avatar
fair enough! thx for the help!
Old Mar 8, 2007 | 11:21 PM
SIvsCobalt's Avatar
try some of the foaming tire spray that you dont have to wipe, it works great but, creates a littler more heat in the engine bay though!!
Old Mar 9, 2007 | 09:37 PM
all-purpose cleaner works very well any kind will do they arent quite as deadly to breathe in as degreaser.
Old Mar 10, 2007 | 07:43 AM
1BadBlueSS's Avatar
Mine is covered with salt
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
Oct 1, 2015 01:07 PM
grampss
Sep 27, 2015 08:51 PM
