Draining Coolent help?
Old Apr 17, 2007 | 05:15 PM
mkulrey13's Avatar
Well i want to install a water temp gauge and the only way is putting a sender in the hose. Does anyone have a how-to/pics on how to drain the coolent and after its drained, can i just readd what i drained to the tank under the hood?
Ok well i figured out how to drain it..witht eh drain plug on the buttom of the radiator but is it ok to poor what i drain back into the system? its only got 40k on it?
No one has ever changed there fluid....thats odd
Old Apr 17, 2007 | 06:57 PM
Florida 76's Avatar
dont mix the pink coolant (Dex-cool) with the geen stuff thats bad... make sure you re fill it with the pink stuff
Old Apr 17, 2007 | 07:09 PM
Halfcent's Avatar
I'm old school
Don't reuse old fluid.
Like mentioned above, don't mix types.
Old Apr 17, 2007 | 07:39 PM
mkulrey13's Avatar
so i can go to like walmart and jsut grab a bottle of pink stuff and use the whole bottle till it fills it up to the line in the tank right.
Old Apr 17, 2007 | 07:55 PM
thmotorsports's Avatar
If you are going to do that than just make sure you are grabbing something that is 50/50. ( 50% coolant and 50% water) Or mix it your self.
To do that grab a large clear water container and add the desired mix of coolant and water. I would not put more than 50% coolant. More water = better cooling.....but worse in the winter. I use about 25% coolant, 70% water, and than the rest redline water wetter.
Anyway...as far as topping it off....fill the whole radiator than let it run a till it's all warmed up. THat is when the fans will kick in and the exchange from the radiator to the engine will take place. Than check the level again....******IMPORTANT***** DON'T OPEN CAP TILL IT HAS COOLED OFF***** Check level and than check the overflow bottle.
Hope this helps
Old Apr 17, 2007 | 08:29 PM
mkulrey13's Avatar
ok is there a place to check on the radiator? sorry im n00b but it sounds simple enough
Old Apr 17, 2007 | 09:57 PM
Halfcent's Avatar
I'm old school
No. You simply fill it.
Old Jul 29, 2007 | 03:48 PM
mkulrey13's Avatar
Do i just fill the coolant tank to the top? then start up? no need to get air out of it?
Old Jul 29, 2007 | 07:45 PM
Halfcent's Avatar
I'm old school
Basically, correct. There always is a little air in the top of the radiator, and its not a problem. Use the instruction on the bottle. I believe it will tell you to top it off, start the engine and let it run, then top it off again.
Old Jul 29, 2007 | 07:59 PM
mkulrey13's Avatar
I sent you a PM .50 cent and thanks for your help
hacadacalopolis
Oct 28, 2015 06:09 PM
EvlPeanut
Dec 30, 2007 06:26 PM
yellowshowbalt
May 27, 2007 08:16 PM
Cyrus the Virus
Mar 13, 2006 08:58 PM
eclipsefloyd
Mar 4, 2006 02:44 AM
