Draining Coolent help?
Well i want to install a water temp gauge and the only way is putting a sender in the hose. Does anyone have a how-to/pics on how to drain the coolent and after its drained, can i just readd what i drained to the tank under the hood?
Ok well i figured out how to drain it..witht eh drain plug on the buttom of the radiator but is it ok to poor what i drain back into the system? its only got 40k on it?
No one has ever changed there fluid....thats odd
To do that grab a large clear water container and add the desired mix of coolant and water. I would not put more than 50% coolant. More water = better cooling.....but worse in the winter. I use about 25% coolant, 70% water, and than the rest redline water wetter.
Anyway...as far as topping it off....fill the whole radiator than let it run a till it's all warmed up. THat is when the fans will kick in and the exchange from the radiator to the engine will take place. Than check the level again....******IMPORTANT***** DON'T OPEN CAP TILL IT HAS COOLED OFF***** Check level and than check the overflow bottle.
Hope this helps
Basically, correct. There always is a little air in the top of the radiator, and its not a problem. Use the instruction on the bottle. I believe it will tell you to top it off, start the engine and let it run, then top it off again.
but it sounds simple enough
