Bad Vibrations
Old Feb 6, 2008 | 12:36 PM
Kristian's Avatar
Bad Vibrations
Any idea what would cause my car to vibrate out of the blue? It was running fine yesterday, then tthis morning I started driving and almost felt as it I had a flat tire in the back or something... so i stopped and looked and my tire was fine. I have no idea what could be causing it...
Old Feb 6, 2008 | 12:37 PM
Drakonen2000's Avatar
loose lugs???
Old Feb 6, 2008 | 12:39 PM
D4u2s0t's Avatar
loose lugs, bad axle, bent rim, bad cv joint, broken mount, etc. can you explain more symptoms? does it happen all the time? only when you turn? only when you brake? only when you accelerate but stops while coasting?
Old Feb 6, 2008 | 12:55 PM
bigrroberto's Avatar
maybe something cracked or came loose because of the temperature change. It's been so very cold now it warmed up... things expand in the warmth remember. Can't tell you what it might be, but that may cause it.
Old Feb 6, 2008 | 02:01 PM
Kristian's Avatar
I notice its alot more evident as I'm accelerating
Old Feb 6, 2008 | 02:16 PM
firestorm's Avatar
another person revolving around E-town!! yay. how many kms you have on your car?
Old Feb 6, 2008 | 02:17 PM
D4u2s0t's Avatar
if it stops when you let off the gas, or are coasting, i bet it's most likely a busted cv joint or a busted mount. have you wheel hopped the car?
Old Feb 6, 2008 | 03:20 PM
Kristian's Avatar
22,000
I haven't wheel hopped the car in at least 6 months
Old Feb 6, 2008 | 03:23 PM
D4u2s0t's Avatar
ok. well i would jack the car up and check the axles, then check the cv joints, then check the mounts. that would be a good starting point.
Old Feb 6, 2008 | 09:12 PM
DoubleLP's Avatar
Flat spot on a tire?
Old Feb 6, 2008 | 10:13 PM
D4u2s0t's Avatar
flat spot on the tire would do it all the time though, regardless of acceleration. would still be there when the gas was let up.
Old Feb 6, 2008 | 10:15 PM
KillerBee's Avatar
Snow stuck inside of your wheels
Old Feb 6, 2008 | 10:19 PM
D4u2s0t's Avatar
again though, why would that only make the car vibrate when accelerating? wouldn't that vibrate all the time regardless of throttle?
Old Feb 6, 2008 | 10:24 PM
DoubleLP's Avatar
Nope..........they said they noticed it a lot more while accelerating.......which could mean there is more vibration as you go faster which could still leave the mud on the inside of the rim in the mix.
Old Feb 6, 2008 | 10:25 PM
D4u2s0t's Avatar
true
Old Feb 6, 2008 | 11:56 PM
Kristian's Avatar
Thanks for all the help! It turns out it was ice buildup behind a spokes on my rims... didn't even see it until i went under my car.. lol
Old Feb 7, 2008 | 12:01 AM
DoubleLP's Avatar
No problem! Gotta love Alberta winters!
Old Apr 5, 2008 | 12:22 PM
Drosmoke420's Avatar
Clean the dirt and salt out of behind all 4 tires that was my problem
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Tupp
Sep 30, 2015 08:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
