Help ASAP with LS4 TB install weird noise
Old Feb 8, 2008 | 01:26 PM
Rodimus_Prime's Avatar
OK so in putting on a LS4 TB everything is on and theres this queefing sound, or like when your farting so hard for that little bit of air and it just makes a high pitched sound. It wont go away unless you take the intake pipe off the TB , then for a second it goes away then the car sputters because its not getting a MAF reading and shuts off
We are using the Rebel Adapter plate and I changed the value in HP tuners that needed to be changed to 4500, is this not correct or is it different for a saturn redline?
Help needed asap
Old Feb 8, 2008 | 01:28 PM
Co|3aLt $$'s Avatar
it's a throttle body queef. rofl check all your connections? everything tight? everything sealed right etc?
Old Feb 8, 2008 | 01:29 PM
yea its all good, nothing lose or gaps or anything like that, im baffled
could the TB be bad
Edubs's Avatar
I can't stop laughing about your description. If I were you, I would check the coupler you are using for cracks or holes. Sounds like you've got a leak. How does it run when it's queefing? HA HA HA
Seriously though, does it spudder, stall, rough idle, anything like that?
Old Feb 8, 2008 | 01:32 PM
Its a brand new coupler it does it with both of them
it runs rough, but is idling better with the new coupler we just got, but the noise is more constant
all i changed was the input area or scaler whatever its called that was 2895 and changed it to 4500 as i have seen in previous posts, no MAF or VE changes
Old Feb 8, 2008 | 01:34 PM
Edubs's Avatar
I think that is right, and I definately don't think that is your problem. You can't locate the origin of the queefing? Don't feel any vaccuum coming from anywhere around the connections?
Old Feb 8, 2008 | 01:35 PM
lsjwannabe's Avatar
maybe the adaptor is bad
Old Feb 8, 2008 | 01:36 PM
Edubs's Avatar
Did you reinstall the o-ring gasket when you installed the TB?
Old Feb 8, 2008 | 01:37 PM
Co|3aLt $$'s Avatar
^^^ my thoughts precisely.
Old Feb 8, 2008 | 01:39 PM
memphisr24's Avatar
maybe you need a new gasket?? Something sounds like it's not sealing properly or something
Old Feb 8, 2008 | 01:40 PM
Co|3aLt $$'s Avatar
take it to the dealership and tell them you hear a queef coming from under the hood.
Old Feb 8, 2008 | 01:41 PM
yea both the orange gasket and the one thats on the rebel plate have been used
Co|3aLt $$'s Avatar
but what is their condition like? are they in good or are they obviously worn?
Old Feb 8, 2008 | 01:48 PM
good
the part number is 12568580
Last edited by Rodimus_Prime; Feb 8, 2008 at 01:48 PM. Reason: Automerged Doublepost
Old Feb 8, 2008 | 01:50 PM
Co|3aLt $$'s Avatar
how does the TB look? everything look correct? any imperfections?
Witt's Avatar
Never saw an LS4 throttle body installed on an LNF before.
Old Feb 8, 2008 | 01:53 PM
The TB is used, it looks ok, I cant see anything wrong, not sure if you can see if there is anything wrong is there something that i should be looking for
what does an LNF have to do with anything , sorry my fingers are cold
Old Feb 8, 2008 | 01:55 PM
Witt's Avatar
Thought it was a strange thread to find here.
Old Feb 8, 2008 | 01:56 PM
lsjwannabe's Avatar
haha
Old Feb 8, 2008 | 02:25 PM
ah
damnit wrong forum
mods please move to correct area
Old Feb 8, 2008 | 04:29 PM
well i kept the orange gasket on the supercharger and then put on the plate to match what the supercharger outlet looks like with the notch thing at the bottom and the black gasket on top of it facing the new throttle body
Old Feb 8, 2008 | 04:37 PM
Area47's Avatar
Rent me! per hour
smart ass.
i wanna hear a queefin throttle body
take some carb cleaner and hose everything down. if the car tried to die. you found the leak
Old Feb 8, 2008 | 05:05 PM
uh, nothing like that lol
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
justinchinn
Oct 2, 2015 12:18 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
