Help ASAP with LS4 TB install weird noise
OK so in putting on a LS4 TB everything is on and theres this queefing sound, or like when your farting so hard for that little bit of air and it just makes a high pitched sound. It wont go away unless you take the intake pipe off the TB , then for a second it goes away then the car sputters because its not getting a MAF reading and shuts off
We are using the Rebel Adapter plate and I changed the value in HP tuners that needed to be changed to 4500, is this not correct or is it different for a saturn redline?
Help needed asap
Help needed asap
I can't stop laughing about your description. If I were you, I would check the coupler you are using for cracks or holes. Sounds like you've got a leak. How does it run when it's queefing? HA HA HA
Seriously though, does it spudder, stall, rough idle, anything like that?
Its a brand new coupler it does it with both of them
it runs rough, but is idling better with the new coupler we just got, but the noise is more constant
all i changed was the input area or scaler whatever its called that was 2895 and changed it to 4500 as i have seen in previous posts, no MAF or VE changes
The TB is used, it looks ok, I cant see anything wrong, not sure if you can see if there is anything wrong is there something that i should be looking for
what does an LNF have to do with anything , sorry my fingers are cold
well i kept the orange gasket on the supercharger and then put on the plate to match what the supercharger outlet looks like with the notch thing at the bottom and the black gasket on top of it facing the new throttle body
DANRICKARD
Oct 1, 2015 12:08 AM
