Bump stop cutting, Alignments, Camber kits for Lowering Springs
Old 01-05-2010, 11:36 AM
  #151
09blackonblack's Avatar
those are getting changed when i do the fe5 struts along with new brake disks
Old 04-28-2010, 07:51 PM
  #152
spunkymonkey's Avatar
hey! i have an 08 cobalt "sport" it looks just like an ss but it had the 2.4...im having problems finding the lowering kit for it...does it have the same suspension setup as a ss? if so can i just buy a ss lowering kit and put it on mine??
plz help...very confused!
thanks
Old 04-28-2010, 10:17 PM
  #153
all the suspensions are interchangable but i believe the lowering kits labeled SS drop more than the non ss drop kits.
at least i know h&r works this way because my first set was for a base model that they had shipped by accident. then i got the correct kit and the car was dropped more to my liking. hope this helps
Old 04-28-2010, 10:23 PM
  #154
Haz l33t wheelz.
ls1fbody's Avatar
it's a 10mm difference. So, 1cm, so less than 1/2 an inch.
Old 04-29-2010, 07:34 PM
  #155
soooo i can swap my stock suspension with the ss suspension? and would it have to be 08 suspension seein as how i have an 08? and if i get what ur saying i can buy the ss lowering springs and they would work on mine??
so many questions i know! lol
but im new to the cobalt tuning world! lol
also if you have any links for lowering springs send them to me plz! and how is the ride quality with the lowering springs and did you have to change anything else of did you just put this on?
Last edited by spunkymonkey; 04-29-2010 at 07:34 PM. Reason: Automerged Doublepost
Old 04-29-2010, 07:38 PM
  #156
Haz l33t wheelz.
ls1fbody's Avatar
Anything meant for an SS would work on your car.
All cobalt suspension components are interchangeable.
I switched to the SS turbo shocks and struts, and i use pedders performance springs. They don;t lower as much, but they have the best ride and handling by far.
Old 04-29-2010, 07:55 PM
  #157
so what model do you have? and know anybody that has ss suspension laying around?
u got any pics of ur bolt u can post so i can see the lowering? and how much did you pay for the ss suspension?
Old 05-17-2010, 12:13 PM
  #158
sake80's Avatar
Coilovers????
I dont know if I should get coilovers when all I want to do is lower my car. I have read that you cant just get spring cause your car will be floaty and also scrub when I get an exhaust. I purchased 18" wheels and still have the factory ride height and it just looks retarded. So my question is, do I really need to buy coilovers or can I get away with springs?
Old 05-17-2010, 02:02 PM
  #159
what?!
Old 05-17-2010, 02:30 PM
  #160
CobaltSSilver's Avatar
Get some springs...what type of Cobalt do you have? I.E Year and trim...lots of folks are liking Pedders right now.
Old 06-02-2010, 11:13 AM
  #161
sake80's Avatar
i have a 08 ls
Old 06-16-2010, 07:41 PM
  #162
arman14's Avatar
I installed the tc/pedders combo like 2 weeks ago and I just noticed that we're supposed to have bumpstops on the front The old struts didnt have them on.
Would riding without bumpstops in nthe front affect anything?
thanks
Old 06-19-2010, 01:44 AM
  #163
arman14's Avatar
bump for an answer
Old 06-19-2010, 02:24 AM
  #164
Haz l33t wheelz.
ls1fbody's Avatar
You need bumpstops. there's an internal one, but it isn't a good idea to run without it. Your old struts should have had one. Call up Tom at CED and get them.
DONT CUT ANYTHING!
Old 06-19-2010, 02:44 AM
  #165
arman14's Avatar
Damn My friend installed my last set of springs, He must have taken them away
I'm calling Tom tomorrow.
Thanks Will.
Old 06-19-2010, 02:46 AM
  #166
Haz l33t wheelz.
ls1fbody's Avatar
Good luck. I had the same issue when i ordered FE5 struts after selling my coilovers. I didn't have bumpstops or top hats. It was horrible. Car sat on jackstands waiting on nothing but springs for 4 months.
Old 06-19-2010, 02:57 AM
  #167
arman14's Avatar
Thanks
I know, it's very frustrating.
I wish I had bought bumpstops and top hats along with the tc/pedders combo
It would have made the install so much easier.
Old 07-03-2010, 04:32 PM
  #168
DCOBALTSS's Avatar
hi guys just installed a h&r springs i guess sport ones bought used from a member here.. there is kinda tock tock noise when i turn my wheels either to the right or left.. and after some reading here and there..
some say they have cut the bumpstops or whatsoever.. i guess bumpstops is what make the car like more stiffy harder on bumps..
so i dont think the problem is coming from bumpstop oh well..
any help from you guys regarding the tock tock noise would be appreciated.. thanks
Old 07-04-2010, 12:47 AM
  #169
get a set of rack spacers from ottp and your problem shall be no more. i have h&rs with factory bump stops, there is no point in cutting them, they are there for a reason
Old 07-04-2010, 10:00 AM
  #170
DCOBALTSS's Avatar
http://www.ottperformance.com/store/...cers-42p87.htm
Is this the correct one and also did you have the same issue as me like a tock tock noise when turning the wheels
and should i take the 1.5in to 2.0in one?
Old 07-04-2010, 10:53 AM
  #171
once in a great while itll make the noise, ive heard some people having it worse than others. and as far as that im not sure which would be better.
Old 07-04-2010, 12:06 PM
  #172
DCOBALTSS's Avatar
do u have the rack spacers man and which one did u take?
Old 07-04-2010, 02:06 PM
  #173
no rack spacers, i went to buy some from ttr but they hit my trans mount so i sold them. currently have none
Old 11-02-2010, 03:56 PM
  #174
Foximus's Avatar
I have an ingalls camber kit, because i was at -1.7 camber up front. The bolts seemed snug and didnt want to easily slide in. This normal? Or am i doing something wrong?
Im on fe5's, sportlines, prothane bushings
Old 04-05-2013, 09:53 PM
  #175
PANIK's Avatar
Originally Posted by montecarloman
Yes you can, go to NAPA and ask then for camber adjustment bolts for your car. Caster is the only adjustment that cant be made without being "creative".
Which kit? im doing the canuck motorsports springs.
NAPA had two different sizes like 1 3/4" and 2 1/2"
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
ineedacobaltss
11-07-2015 02:25 PM
Tupp
09-30-2015 08:18 PM
09-26-2015 06:44 PM
Quick Reply: Bump stop cutting, Alignments, Camber kits for Lowering Springs
