08 Turbo fit 07-05 balts?
Old 10-23-2007, 01:11 PM
SSMOKEM's Avatar
Maybe too early to ask this question, but do you think a GM vendor will offer the turbo setup to fit the past cobalts, Like crate engine depot? Or are things too different to match up?
EDIT: Should have said fit the SS/SC
Old 10-23-2007, 01:24 PM
Onyxd04Redline's Avatar
The LNF is a Direct Injection engine while the current 2L is not. I imagine the engine will fit perfectly but you'll need to run new fuel lines and run a new tank and pump.
Old 10-23-2007, 01:54 PM
Novajoe's Avatar
I don't see what that has to do with mounting the turbo to the engine unless you were going to use the LNF intake manifold as well.
I'm not totally sure on the bolt pattern of the new heads though. Since they have direct injection the head has to be different. Hard to say if they changed the bolt pattern or not.
So anyone at a gm parts counter wanna match up the exhaust manifold gaskets for us and see if they're the same?
Old 10-23-2007, 11:39 PM
SSMOKEM's Avatar
hmm thanks for tje info!
Old 10-23-2007, 11:43 PM
Scythe_Snake's Avatar
I know the LNF has VVT in its head, and the turbo should mount up but will need some work to it like said earlier. But as for just a quick bolt on...I doubt it.
Quick explaination of the whole direct injection thing?
But yeah, kind of too early to be thinking about that. Let them damn thing come out first.
Old 10-23-2007, 11:56 PM
tricky1's Avatar
http://en.wikipedia.org/wiki/Gasoline_direct_injection
Old 10-24-2007, 01:44 AM
Whoops.
Oh, I thought it was something special. I misunderstood. Thanks.
Old 10-24-2007, 01:48 AM
Admiral Jedi's Avatar
Why would you want to swap in the whole motor? Will the LNF bolt to the trans?
You could get just as much power from building your LSJ for much easier.
Old 10-24-2007, 04:35 PM
Okay, the direct gasoline injection thing still bewilders me. It looks like its using fuel injectors like we do, and is doing the same exact thing. WHats the all the joy jumping about DI?
Old 10-24-2007, 04:37 PM
D4u2s0t's Avatar
there's plenty of turbos currently available. why would you specifically want this one?
Old 10-24-2007, 05:20 PM
lijewski's Avatar
Direct injection sprays directly into the cylander instead of the manifold like on the LSJ (multiport injection). Direct injection gives you more power from less gasoline. That isthesimplist way to explain it.
Old 10-24-2007, 05:23 PM
Raven SS's Avatar
LNF turbo is gonna be maxed out on power from the floor room go aftermarket
Old 10-24-2007, 07:36 PM
Originally Posted by lijewski
Direct injection sprays directly into the cylinder instead of the manifold like on the LSJ (multiport injection). Direct injection gives you more power from less gasoline. That is the simplist way to explain it.
Oh okay. Thank you very much! If I could rep you I would, but thanks very much.
This is true.
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
hacadacalopolis
10-28-2015 06:09 PM
maliki778
10-01-2015 07:39 PM
roth
09-26-2015 12:16 PM
Quick Reply: 08 Turbo fit 07-05 balts?
