09 BPV solenoid removal.
Old 03-28-2015, 02:18 PM
blueLNFftw's Avatar
I can run the stock BPV directly from the IM and cap the charge pipe vacuum line; correct?
No need for the electric solenoid?
Old 03-28-2015, 03:57 PM
blueLNFftw's Avatar
No one?
Or do I have to ask about painting my brakes or what color plastidip to get views?
Old 03-28-2015, 04:36 PM
Wouldnt you get a code if you dont have the electric solenoid? I wish i could help but i dont know the answer lol
Old 03-28-2015, 07:42 PM
kzak104's Avatar
Ya you can run it right off the manifold no problem. You'll either have to leave the solinoid itself electrically plugged in or have the code removed through the tune or it will throw a light. Won't effect anything tho.
Old 03-28-2015, 07:48 PM
yeah I don't think it does once I disconnected the solenoid and forgot to reconnect it, I got the code but I never really noticed a difference in performance. but I didn't really know it will affect anything in the long run
Old 03-28-2015, 08:38 PM
T-fog's Avatar
I understand what is being done, But I don't know the purpose of it.
If someone doesn't mind explaining I would like to know why someone would do this? What is the benefit of doing this?
Old 03-28-2015, 09:11 PM
kzak104's Avatar
I only didnt it to run a bov my my turbo kit. Solinoid didnt open fast enough. Other than that I dunno why someone would remove it.
Old 03-28-2015, 09:22 PM
tomj77's Avatar
u can run it from the intake manifold port, but not from the lower charge pipe port, that one only sees boost not vacuum, which u need to open the bpv. if u do go straight from the intake manifold, u will have to put a hose on the solenoid from the bpv port to the bottom port on the solenoid, if u just leave the bpv port open when u switch gears or whatever, ull have a vacuum leak at that port, and while in boost, u will have a boost leak at that port, the way the solenoid works is when ur in boost, the top port on the solenoid that is connected to lower cp is open pushing boost on the bpv holding it closed, when u shift or whatever, that port closes and the bottom one opens providing vacuum to the bpv, opening it. that should help you. if u have a zzp lower pipe u can just remove the vacuum nipple and put a plug in, then u can just completely remove all vac lines from solenoid and just plug the bpv straight into intake manifold and nothing else.
Old 03-28-2015, 09:26 PM
tomj77's Avatar
I had same issue, but just going straight to im, didn't help, the problem is the spring in the bov is too stiff. I put a lighter spring, it was better but not enough, so I ran both bpv and bov, that worked, thinking about it, what would work the best is putting a really light spring, like a 4 psi or something into the bov, then running off the solenoid, otherwise if ud run off the im manifold with a light spring like that the bov is open at idle.
Old 03-28-2015, 09:27 PM
tomj77's Avatar
and regardless what u do, leave the electrical connection on the solenoid plugged in
Old 03-28-2015, 09:30 PM
kzak104's Avatar
If he's tuned he can just unplug it and delete the code. Thats what I did.
Old 03-28-2015, 10:10 PM
tomj77's Avatar
Or that. I don't like deleting codes, wish u could just turn things off. Like rear O2 , I can delete the code cause when it gets full of moisture it pops, but even so car will still start funny. So I just leave em. Not that it would happen with that.
Old 03-28-2015, 10:52 PM
kzak104's Avatar
You just drive with a check engine light? How do you know when something is actually wrong?
Old 03-28-2015, 11:17 PM
You could scan it every other day
Old 03-28-2015, 11:28 PM
kzak104's Avatar
lol, i guess you could...
Old 03-28-2015, 11:29 PM
Lol annoying but you could
Old 03-28-2015, 11:31 PM
kzak104's Avatar
to much work for me :P ill delete the codes, haha
Old 03-28-2015, 11:41 PM
i would too
Old 03-29-2015, 12:29 AM
tomj77's Avatar
I don't delete the codes, when it pops, I fix it.
Old 03-29-2015, 01:13 AM
kzak104's Avatar
When what pops. The cat? The solinoid? I'm confused
Old 03-29-2015, 02:05 AM
tomj77's Avatar
o2 sensor code. lol u gotta read my post where im talking about why I don't like to delete codes in the tune. I think u misunderstood and thought I ment when the engine light comes on I don't delete the code, I ment I don't like deleting the codes from the tune. like rear o2, cause if there is a problem u will still get symptoms but no code, so u wont know whats wrong.
Old 03-29-2015, 02:23 AM
kzak104's Avatar
oooh, i see, i dont delete the o2 sensor codes, just the cat efficiency code
Old 03-29-2015, 10:17 AM
blueLNFftw's Avatar
Thanks guys.
I'll delete the code. I just wanted to make sure the BPV could do it.
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
hacadacalopolis
10-28-2015 06:09 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: 09 BPV solenoid removal.
