Analog Boost Gauge Swap
i have a '10 ss, and i would like to have the analog boost gauge. has this swap been done before or does anyone know how hard it might be? i tried searching for this, but i didn't find anything. thanks.
I'd have to check out the wiring schematic. I've done an analog-to-RPD conversion for a friend, but I don't think you can do it the other way because you don't have the boost signal wire in a factory RPD car.
Your options are:
Keep the RPD and hope a vendor finally comes out with an RPD + gauges pillar.
Keep the RPD and mount a boost gauge separately, running off of a vacuum line.
If you can find an output or wire for the boost signal, like is on the cars that came with the analog gauge, then I think it would be possible.
Your options are:
