Bnr k04-gt28
#1428
Update:
I was able to work something out with Bryan at BNR. It seems I will be upgrading to the 2871 and needing new hot side CP with BOV flange and a BOV. Not sure how to run that setup yet since I never researched BOV on the LNF cause I wanted to stay away from them LOL
Anywyas, looks like he will be pulling the 2860 from the site as an upgrade option for now. He really is a cool guy and willing to work with his customers to keep them happy.
#1431
Update:
#1432
Update:
#1434
#1435
Update:
![Twothumbsup](https://www.cobaltss.net/forums/images/smilies/twothumbsup.gif)
As far as BOV, I used my non BOV UICP.
I ordered a Tial Q BOV w/ flange (I would get a 6psi spring and use the factory solenoid for the BPV if it was me).
Put the flange where I wanted on my UICP. Which happened to be same location as ZZP but on the opposite side of pipe, I wanted the shortest vaccum routing possible.
I traced ithe BOV flange on the inside with a paint marker, cut it out with a dremel.
Then I sanded it to the metal around the hole so when the BOV was welded it would get a good weld.
Then I took the UICP and BOV to a good aluminum welder, paid $20 bucks, brought it home, masked off the flange and painted it with dupli-color factory Victory RED (Pipe was already powder coated victory read previously). Done
Turned out pretty damn good if I say so myself, maybe one of the Bama peps will chime in, they saw it this last meet.
Or
You can spend a little more money and have it all done for you.
I paid $250 for authentic Tial Q BOV & aluminum flange, $20 for welder, $7 for paint. I already had a dremel and the UICP.
vs. cost of new UICP with flange welded on already + BOV
#1436
Well, atleast we will have someone now that will be able to compare both models ![Twothumbsup](https://www.cobaltss.net/forums/images/smilies/twothumbsup.gif)
Or
Or
Im definitely going to use my CP and do what you did by cutting into the pipe and having the flange welded on. The only dif though is I plan to recirculate the vented air back into the intake so I dont have to relocate the MAF. Im just having trouble distinguishing the VTA and recirc BOV and cant find the recirc adapters that are sold for the BOV.
#1437
HAHA! It will be good to have both turbo numbers on the same car. Good info for the community. Bryan is def being really cool about all this.
Just finisehd up installing my MAF relocate today on the HHR SS, I had to modify the ZZP MAF relocate pipe to line up with my IC. It wasn't a big deal as it was just bending one of the 90's at the end a little more.
The ONLY reason to get a MAF relocate or recirculate your BOV is you get a very very very slight stutter between shifts (rich spike) and when you ride with the cruise control on up and down hills without the relocate or recirculate.
Other then that I have had a BOV with no MAF relocate for over a month and the car ran just fine.
Wife wanted the MAF relocate to be honest for when we go on trips. The stutter thing drives her crazy with cruise on.
If you want a loud BOV do not get a Tial Q its the quitest BOV I have ever heard VTA other then a recirculated one. You would think that big ass Tial Q would be loud, thankfully its quite.
#1438
#1439
You don't need a MAF relocate to run a BOV on the car... Ive done several VTA BOV's without it and they ran just fine. And anything w/recirc is going to be a bit quieter then the normal VTA version.
HHR - your stutter is from the tune not being setup right for a VTA BOV
![Wink](https://www.cobaltss.net/forums/images/smilies/icon_wink.gif)
#1440
HHR - your stutter is from the tune not being setup right for a VTA BOV![Wink](https://www.cobaltss.net/forums/images/smilies/icon_wink.gif)
I bet none of the Bama peps at the meet Sunday noticed it when riding in the HHR SS.
#1444
Cool. This one seems to be the easiest option out there. We pull about 15 in/HG right so, what, the 10psi spring right? THats rated at 12 in/HG.
I found the GReddy and the adaptor to make it a recirc but all together would be like 330 lol
#1445
With little/no load on the engine, I pull -9psi to -10psi, which should roughly translate to -18in/Hg to -20in/Hg. This means that you'd typically want a spring that's just a bit more than that same amount of psi.
Too soft of a spring, and you'll get a boost leak, since the BOV/BPV would vent. Too firm a spring, and you'll risk compressor surge.
The engine vacuum tries to suck open the valve, and the spring counteracts and tries to push the valve closed. You want the valve closed normally, and yet easily opens when additional pressure builds in your charge pipe over what is in your intake manifold, when letting off the throttle or changing gears.
#1447
Tial Q 6psi BOV spring here, stays closed at idle and reacts fast as hell.
#1448
Drewbroo told me to do the solenoid method and 8 psi spring (because he was having the flutter with the direct manifold method also) and its a night and day difference then hooking it up to the manifold. Waaaay better.
I then went ahead and traded my 11psi spring with Tial for a 6 psi spring to see if it was faster and would work since Drew never tried it and its sweet. Solenoid keeps it closed and vents fast.
