Bnr k04-gt28
#177
I highly doubt BNR is going to invest all the time in research, tooling, jigs and setting up CNC programs for our particular K04 to have it fail. Don't forget hes been converting factory turbos for other platforms as well.
#178
yeah because I am doing this option pretty sure .. So you will have multiple people to tune with and get the bugs worked out if you wanna go in on it together ...
I don't really like aftermarket BOV's for the sound effects so what wheel do you think will hit 400 , thats the one I want .
#181
Cause Im in the same boat as you. Im not going to mess with BOV and MAF relocate, but Im under the impression that 360whp would be safe and efficient on the 2860.
#182
#183
If you go 2871 does that mean new clutch? What other supporting mods would you need? I have full bolt ons at this point, but if I were to do this I would want to do it at minimum cost...
#184
I would think if you wnt conservative with the boost delivery to avoid shocking the clutch the stocker should hold.
#185
I'm curious how these turbo "upgrades" would fair with a fully bolted Balt. And maybe one that is fully bolted with a good clutch and some pistons. I wanna hit the low 400s at the wheel and this seems like the best way to go about it.
#187
You just described my balt. Full-bolt-ons and pistons. Im looking at the 2860 and maybe 360whp. Thats all I want. Thats enough power for me to have fun with it still as a DD and some time at the track too
#188
Taking into account that there will be an efficiency reduction associated with putting those larger wheels in our housing, albeit reconfigured, I am expecting it to be 5% or so less efficient than a regular GT2971R.
#190
Yes, should be a tad less efficient than a "real" gt2871, but still a major upgrade over the stock k04. As you said, the cost to benefit ratio of this upgrade will be good and I am 100% for that, I bought a cobalt after-all! I can't bring myself to spend 25% or more of my car value for a turbo upgrade!
#194
I might make a vid tutorial how to remove and install the stock turbo..
It is still over some peoples heads but with a video maybe every one would have the confidence to yank it out and send it on over to BNR...
#196
So I'm thinking about this for my sky. It will get great to see some dyno numbers. I might be going for the stage 1 just to leave everything stock except for the turbo. Would be nice with a trifecta hide a tune.
#198
The 2860 in the stock housing (Stage 1) would probably be maxed at 375hp, as long as you have intake, intercooler upgrade, and full exhaust. It also depends on elevation and other factors but 380-400 is perfectly feasible. Ive heard of people pushing disco potatoes to 26psi for years with no problems. Thats still a gain of 65hp over a TC with full bolt ons and Trifecta tune. That is a little bit optimistic but the Stage 1 will add way more than 20whp, probably more than 40whp honestly.
#199
