Bnr k04-gt28
Old May 10, 2011 | 12:38 PM
  #1701
BYT*SS*TURBO's Avatar
We have been making well over the 400 mark on cars with a Blend Tune lately
Old May 10, 2011 | 12:40 PM
  #1702
Terminator2's Avatar
Originally Posted by drewbroo
Feels like well over 400 ftlbs. My guess is 330/410 on the mustang. I am going to dyno the TF E85 tune vs the BYT E85 Tune.
I would say on a dynojet 335-340 whp and 390-400 wrtq I am thinking it will be about 10% lower than that on that mustang dyno. We will see. Your coupe fully bolted on the stock turbo was trapping 3MPH higher than the sedan IIRC.
Old May 10, 2011 | 12:42 PM
  #1703
drewbroo's Avatar
the 4 door seems to like the full E right now. Its really likes the TF tune I have on there too. Pull wise I can't really tell a difference.
Old May 10, 2011 | 12:50 PM
  #1704
09CobaltSS1's Avatar
damnit I seriously wish there was e85 readily available in my area!!
Old May 10, 2011 | 12:57 PM
  #1705
Sweetsandman's Avatar
It's nice
Old May 10, 2011 | 01:10 PM
  #1706
HHRSSouth's Avatar
Battle of the LNF E85 Tuners
Old May 10, 2011 | 01:29 PM
  #1707
drewbroo's Avatar
I am not battling any tuners, everyone I have dealt with is really good. (Other than superchips)
Old May 10, 2011 | 01:30 PM
  #1708
WSox33's Avatar
Why not just get a real turbo and make some real numbers?
Old May 10, 2011 | 01:32 PM
  #1709
HHRSSouth's Avatar
Trust me man, if you don't want to stir up any trouble, I would not post a comparison test of Trifecta vs. HPT E85 results.
Its just going to start the whole Trifecta HPT battles again that are never ending between people.
Old May 10, 2011 | 01:34 PM
  #1710
I guess 367/424 on stock turbo isn't real enough lol. Look at the dyno list and how many big turbo cars didn't make 400whp. Not to mention, the car is already worthless traction wise at this level. 3rd gear just laughs at the pavement now..
John - Growth Energy Market Development
I drive a bit out of my way to fill up BUT if you do a blend tune it will last a decent amount for you. We saw minimal gain going from 1:1 to 2:1, so you could really make it last with a E30 blend and still get the power boost
Stir it up.. I haven't seen any TF customers post a over 360whp graph on E like we have.
Last edited by BYT*SS*TURBO; May 10, 2011 at 01:34 PM. Reason: Automerged Doublepost
Old May 10, 2011 | 01:41 PM
  #1711
drewbroo's Avatar
its all in how much time is put into the car too. Some people don't get their car fully dialed in by vince and just throw it on a dyno.
Old May 10, 2011 | 01:43 PM
  #1712
drewbroo's Avatar
I guess reading fails you, check my sig. I don't need a car with a "real turbo." Also I am all about research and development for the community, I am not all about dyno numbers, I am about the whole picture. (1/4 mile times and drivability.)
Old May 10, 2011 | 01:45 PM
  #1713
I am curious to see what Drews 4 door puts down on E-85. The torque limit on E-47 appears to be approx 430 wtrq (on that mustang dyno anyway). I still see no advantage going above E-47 in most cases.
Old May 10, 2011 | 01:49 PM
  #1714
Because ~400 whp and 430 wtrq on a mustang dyno and a powerband from 3K-past 7K RPMs is not an improvement over stock? He already has traction issues in 3rd gear in 100* dessert heat at 3,600 ft above sea level.
Old May 10, 2011 | 01:51 PM
  #1715
We made 447wtq on a couple pulls with a Eblend car.
Old May 10, 2011 | 01:54 PM
  #1716
cubaniche's Avatar
Yeah the only real advantage to running full E is to be able to pump just once when you gas up and to minimize the fluctuations in the mix that you may get from fill up to fill up.
Old May 10, 2011 | 01:59 PM
  #1717
drewbroo's Avatar
I do not know why, but the powerband seems to be better on a full E car with little mods.
Old May 10, 2011 | 02:02 PM
  #1718
Matt M's Avatar
Originally Posted by Terminator2
I am not "talking ****" as you put it. What I am saying about torque limits and fueling has been proven time and time again by me and the other tuners of this site and yet your car is magic it somehow makes more torque on E-74 without hitting the fueling limit than the cars I tune on E47 or even E-30. Sorry but the torque limit on E-74 no what you do with the injector constant, rail pressure ramping and injection timing is much lower than your car was able to make on the stock fuel system. Your car made 240 whp SAE stock on your mustang dyno you posted the dyno sheets right after you picked the car up. So if you take that 10-12% difference that normally exists between a dynojet and a mustang dyno your car made 264-270 whp SAE stock on a dynojet?
1. My car doesn't have to be magic. We learn new ways to make more power. That is our job. I notice that you ignored my statement that I trapped 119mph right after I dyno'd 356 on our dyno.
2. Yes, I have seen stock LNF Cobalts make 260 on Dynojets.
3. Now you are stating that the difference between Mustang and Dynojet is 10-12%, but you have simply moved into the next topic that you still have a lot to learn about. As I'm sure you know, Mustang dynos require vehicle weight to be entered. You may also know that the number that you enter affects the hp numbers. Because of this, lighter cars do not take as much of a hit on a Mustang dyno as a heavier car. While a 4000 lb car might lose 10-15% by going from a Dynojet to a Mustang, a 300 lb car might only lose 6-10% This is something that is rarely discussed, but should be.
Old May 10, 2011 | 02:03 PM
  #1719
Different dyno though. That is why I put in parentheses on that mustang dyno.
Old May 10, 2011 | 02:05 PM
  #1720
Did you try E-47 in the 4 door first? Or just strait to E-85?
Old May 10, 2011 | 02:08 PM
  #1721
Matt M's Avatar
Another thing that people have to realize is that we know how to get power out of cars on the dyno. Similar to what is commonly known as the driver mod, it works the same way on the dyno. It just is what it is.
Old May 10, 2011 | 02:10 PM
  #1722
drewbroo's Avatar
This is true. I wish I could have been doing the driving for my dyno pulls.
Old May 10, 2011 | 02:14 PM
  #1723
drewbroo's Avatar
The dyno I was on you enter in the weight of the car. Anyways, the car will be dyno'd on the same dyno so I can see what real world gains I get.
Old May 10, 2011 | 02:18 PM
  #1724
That and he used 4th gear on the pulls. Although we have no perfect 1.00 : 1.00 gear fourth is technically an overdrive gear at 0.89. Third gear is 1.19 so neither is perfect but I like to use 3rd gear. When you do the sedan ask him to do both fourth and third gear pulls to see what the difference is.
Old May 10, 2011 | 02:19 PM
  #1725
Gremlin85's Avatar
I've done 3rd and 4th gear pulls and saw no difference in power at the wheels. I found it odd.
