boost leak???
boost leak???
i was driving today and did a no lift shift and it seemed before i shifted it sounded like a bunch off air just came out of somewhere alot louder then the bypass valve has anybody ever heard hti sbeffore??
What did the car feel like? you only described what you heard....did you loose power . I mean you obviously were at WOT if u were performing a no lift shift?
Did you shift fast enough for a No lift shift or whatever? Just asking.
it happens all the time. it depends on when you shift and how much pressure the turbo builds up. the last time i did that the ecu threw a code til the pressure went away. i guess its the wideband that detunes the cars performance
n20saturn
Sep 30, 2015 12:26 AM
