boost leak???
Old Aug 4, 2008 | 06:21 PM
GOONIE's Avatar
boost leak???
i was driving today and did a no lift shift and it seemed before i shifted it sounded like a bunch off air just came out of somewhere alot louder then the bypass valve has anybody ever heard hti sbeffore??
Old Aug 4, 2008 | 06:24 PM
sherm420's Avatar
nope..
did the CEL flash?
Old Aug 4, 2008 | 09:40 PM
GOONIE's Avatar
no it didnt it made this noise a couple of itmes before i wonder hwta it could be do you think it can be a possible leak?
Old Aug 4, 2008 | 10:35 PM
FiscalFizz's Avatar
ummmm, not 100% sure, but a boost leak= major failure...correct? Ok then.. if you had a legit boost leak, wouldn't the Check Engine Light flash or come on? I mean. its hard to not get a CEL once in a while over minor ****..... so if you had a legit boost leak, pretty sure u would get a CEL or something.
What did the car feel like? you only described what you heard....did you loose power . I mean you obviously were at WOT if u were performing a no lift shift?
Did you shift fast enough for a No lift shift or whatever? Just asking.
Old Aug 4, 2008 | 11:50 PM
GOONIE's Avatar
i shifted at bout 5700 RPM it did seem to lose a tiny bit of power but only for that split second it sounded like a bunch of air released (not the bypass) dnt know what it was
Old Aug 5, 2008 | 12:27 AM
hungryhip-ccp's Avatar
the internal wastegate blowing off the extra boost?
Old Aug 5, 2008 | 12:34 AM
FiscalFizz's Avatar
well.. did it sound sweet LOL... take er in
Old Aug 6, 2008 | 04:24 PM
blackrocky's Avatar
it happens all the time. it depends on when you shift and how much pressure the turbo builds up. the last time i did that the ecu threw a code til the pressure went away. i guess its the wideband that detunes the cars performance
Old Aug 6, 2008 | 05:57 PM
GOONIE's Avatar
...gay
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
