Boost Spike at High RPM?
Old Jun 24, 2011 | 12:45 AM
kplaya186's Avatar
With the Stock tune on my boost in 2nd gear has been spiking from 15 PSI to 17 PSI at RPMS above 5k. Any recommendations to figuring this out? They only thing I can think of is that I have a boost leak somewhere??
Thanks in advance.
Old Jun 24, 2011 | 02:44 AM
bogalusahondakiller's Avatar
mine does the same. over 5k i go from 15 stock to 20
Old Jun 24, 2011 | 09:32 AM
BYT*SS*TURBO's Avatar
That is normal and how the stock tune runs.
Old Jun 24, 2011 | 09:55 AM
jms041288's Avatar
I had that problem after I was tuned. Bought the Forge bypass valve with the stiffer spring it helped alot
Old Jun 24, 2011 | 10:26 AM
He isn't tuned..
My car stock would hold 15psi and then rise to 17-18 like you are seeing.
Old Jun 24, 2011 | 10:57 AM
CudaJoe's Avatar
I see the same thing stock and with the Forge unit so its not that. Its to keep the car accelerating all the way to redline and not fall on its face too much, lol. Its the stock tune and I think its to make up for our little K04
Old Jun 24, 2011 | 11:48 AM
kplaya186's Avatar
Just to clarify my mods: Forge BPV - green spring, K&N Intake, Catless DP, and TF 23 PSI tune. I get this spike only in the stock tune. So this is normal? Seems weird because most turbo cars will spike early and settle out?
Old Jun 24, 2011 | 11:54 AM
again, that is normal for the stock tune lol..
Old Jun 24, 2011 | 11:56 AM
Permafried-'s Avatar
Are the stock tables setup to to do that to compensate for the K04 falling on its face so pushing more air = maintaining the target tq?
Old Jun 24, 2011 | 12:07 PM
Prolly more for gas mileage. This way the car is tame around town and then when you want to go it will ramp up and take off.
Old Jun 24, 2011 | 12:08 PM
Thanks, makes sense .
Old Jun 24, 2011 | 08:32 PM
kplaya186's Avatar
Side note.... Stock tune feels as slow as **** after running the tune for a little bit.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Trav3480
Sep 28, 2015 02:46 PM
