Cobalt SS\SC to Cobalt SS\TC
Hello Forum
I now have a Cobalt SS\SC and have the opertunity to maybe get a 09 SS\TC.
I still have a few questions about the SS\TC owning my SS\SC now for 2 years and had quite a few problems in the past with it.
1) how many have switched over from the ss\sc to the ss\tc ,how much better do you like it?
2) the dreaded axle problem,Does the SS\TC suffer the same problem as the ss\sc with the axle problems or have they been improved or upgraded?(My 06 has been through 2 set of axles and 1 set of lower control arms.
3) Is there a big notice of power differents between the ss\sc and the ss\tc (stock for stock) does it have the pick up off the line like the ss\sc?
4) Really how much more improve is the ss\tc over the ss\sc from previous owners of both cars(ss\sc and ss\tc)
5) anything else I should know between the ss\sc and ss\tc i may have left out for questions you can fill in,Like to make the change but wanted to get some info from people who made the switch.
Thank You Forum
Thank You Forum
1.) Some have switched from the SS/SC to the SS/TC, but many are sticking with their LSJ's. The people that have switched over, really like their new SS/TC.
2.) It does NOT suffer the same axle problems. Chevy re-engineered the way the harmonics are vibrated, and it has improved that axle problem.
3.) There is not really a big power difference. It does not pick up off the like the SS/SC does, because the turbo has to "build" up power. They have different power spots.
4.) The SS/TC does have some improvements over the SS/SC. The Brembos, RPD, axles, suspension...
All in all, the SS/SC is a great car, but the SS/TC just built upon that platform, and made it phenominal!
To add to #2 , the axles are also slightly beefier . Motor and both trans mounts have a different durometer rubber . And the clutch have been enlarged over the SS/SC version .
Basically the entire suspension is revised . Spring rates , shock valving , the way the steering rack mounts to knuckles , the entire steering rack itself including recalibration of the steering rack module which now a variable rate . Front lower control arms are revised .
Do yourself a favor a drive one for yourself and base your own decision , as its pretty different car as a whole to the SS/SC , and alot the LSJ diehards have a bit of problem admitting the new car is better overall ....no , Im not reffering to anyone who posted in this thread as of yet
. Not mention the fluff stuff , like new ( better imo over the Recaros that I had ) seats , the quite useable performance display , bluetooth , more brake than youll ever need , 2 minute front pad changes on the brembos
IMO , the new one is basically everything I wished my SC car was when I bought it new back in 05 . And sure , the LSJ is quite capable of being built to smack the **** out of the new car but at a higher cost . When modding comes up , I cant help but make a comparison back to when GM put the LS1 in the Camaro's . Like the LS1 camaro's when compared to a LT1 , the LNF cobalts are gonna be way cheaper to make stupid fast over a LSJ . With LNF cars pushing damn near 12's with a tune limited by access to all aspects of the PCM , modest traction and couple exhaust mods .
JMO , Im sure boatloads will disagree
Well for all you members that where following this thread and gave input.
I took the cobalt ss\tc out for a ride today.
I must say WOW!!! what a differant car with in 3 years.
I noticed the upgraded things from the ss\sc to the ss\tc right away.
power is extremely noticable(nice pants in seat) over ss\sc,handling is day and knight(wider tire I believe 225 40 18)
I must admit ... Wont miss my silver 06 ss\sc if I do make that switch and its a really good shot I will.
Well the SS\TC I plan on getting is loaded to the gill (yes has the big wing)
But the color just blow me away!!! Im getting it in Tint Red
So just wanted to give a update and say it maybe Bye Bye
SS\SC
And..PS may have to change name now
Thanks for info all
SS\SCAnd..PS may have to change name now
Thanks for info all
Well, if you get the SS/T I'm sure you're gonna love it.
Seeing how you were WOW'd by the power though, I'm guessing your SC doesn't have Stage 2 like my car does.
Personally, I don't care about the Brembos, adjustable suspension control, seats, etc.
Just gimme the bigger clutch and them stronger axles, Chevy can keep the rest ...
About the axles - here are some pictures I snapped of the driver and passenger axles. The socket extension is for size comparison - it is a standard craftsman extension.
For handling - I dont know if they stiffened the actual chassis at all over the S/C, but this really surprised me when I went to install the hahn 3" exahust. This pic does NOT have a jack stand under the rear wheel, and I was able to open and close the passenger door normally -
Oh, and for grins - here is the stock intercooler on my table (this is the one I cracked - anyone interested in it with a crack in the plastic end tank? PM me)
I also to the 09 ss/tc for a test drive... the power difference is there but it's not a big jump in power by all means. It is smooth, sounds nice when the turbo kicks in, and handles great, but i didn't find the brakes to be very good, my ss/sc brakes are better and there stock (might have nbeen becuase they were too new)... Noetheless it's a great car but i like my ss/sc better becuase i find these cars are much more responsive.... Turbos have to biuld power=lag, superchargers have power on demand.. and i love the sound of the supercharger... But i gotta say the seats are a very big jump from the ss/sc..
unless you got some secret special brakes from GM im pretty sure those Brembos would beat the **** out of your stockies. and a lot of people find the turbo to be slow due to they dont know how to drive it and the dealerships only put 87 in the tank for savings so they are slower. now i still dont see how a stage 2 is pretty close to equal to the turbo. not trying to hate, just want to see a race against two GOOD drivers. ive seen the youtube videos. they all have things done to them. still, the turbo will make more power for the buck vs the sc.
In a braking comparison the brembo equipped SS/TC stopped from 0-60 6 feet faster than a SS/SC . IIRC it was 121ft to 127ft. Better yes , beaten the **** out of .... well that depends which car you own.
I've raced one from a 40 roll and to my surprise beat it by half a car maybe more went all the way to about a 100. Super Ed was with me cause we all raced from the same roll. It was pretty cool actually .
I meant super ss damn I phone lol
Cobalt SS Supercharged - Braking, 70-0 mph: 160 ft
Cobalt SS Turbo - Braking, 70–0 mph: 162 ft
Source: Car & Driver
http://www.caranddriver.com/reviews/...cs+page-2.html
I'm not trying to start **** , but "some" of the new TC owners have really developed an attitude about their car's . The TC is better no doubt , but ive see them call the SC a piece of **** , or not even comparable to their "New" SS.
Wow good find , i was searching last night for the post i made about the distances i posted above but couldn't find it. I'm shocked the 05 SC stopped quicker from 70. I know the SC brakes will prolly begin to fade before the brembo's but you would think that the brembo's would outperform the SC's brake in any contest.
I was also curious about the difference in stopping power between them and this test shows that both calipers have sufficient force to stop our Cobalts. The small difference was most likely due to tires and pavement conditions.
I believe both brake setups are fade free at stock power levels. I've only had track time at 205HP, so I can't speak for stage 2 however.
IMO make the switch. As others have said the SS/TC is an improvement over the SS/SC in every way.
Don't get me wrong, I LOVE my Stage 2 SS/SC and to me the SS/TC doesn't feel quite as quick.. because it IS a slight bit slower in a straight line. But not even enough to matter, it's a drivers race. If I were a fat person I'd probably lose to an SS/TC. That's how close it is.
After driving the TC I am very impressed. It's as fast as my Stage 2, handles better, the brakes feel INCREDIBLE, and the car feels amazingly stable even at very high speeds.
It's also going to be ridiculously cheap and easy to mod to be faster than 95% of SS/SCs with a LOT of money put into them.
If you can get any decent deal at all, I'd say go for the switch and start with a tune...
I doubt you'd regret it.
P.S.
The RPD in the 2009 models in the coolest feature of the entire vehicle.
P.S.
P.S.
The PPD in the 2009 models in the coolest feature of the entire vehicle.
P.S.
What kinda cool feature is that?
RPD...............
But even as an SC owner, in all fairness I'm guessing the SS/T's Brembo's resistance to fade from prolonged/repeated braking is likely superior to that of my SC's.
