Are dealers farmiliar with the GMS1 tune upgrade
Old Feb 29, 2012 | 03:24 PM
UltraMagnus86's Avatar
Originally Posted by r1owner
Just ordered from CED! Can't wait to put it in and get it tuned.
Hey keep us updated on your experience getting it tuned from the dealer.
Old Feb 29, 2012 | 03:39 PM
NiceBaltSS's Avatar
x2........I'll be going through all of this come spring time!
Old Feb 29, 2012 | 03:40 PM
r1owner's Avatar
Will do. Anyone know how to verify if the ECM was indeed updated?
Old Feb 29, 2012 | 04:07 PM
guitarenvy's Avatar
The flash is required or you will have an engine light on with the new sensors installed.
Old Feb 29, 2012 | 04:35 PM
soundjunky's Avatar
ecm updated?
you mean reflashed?
if you haven't been reflashed, going into boost with the GMS1 MAP's will put you into limp mode ~ because the values are read differently....
after you've been reflashed, you can make boost, and the gauge will show it, and you won't be in limp mode.
Old Feb 29, 2012 | 05:34 PM
r1owner's Avatar
Yeah, didn't even think about the check engine light. I'll prolly wait till I get back from my trip in March to get it all setup.
Old Feb 29, 2012 | 06:22 PM
09TcSedan's Avatar
x3! i want to know if my buddy (who works at the dealership) can do this on the side for some cash instead of paying a hour or 2 of labor. idk what has to be done to 'reflash' the ECU but i can imagine it would be to crazy
Old Feb 29, 2012 | 07:54 PM
guitarenvy's Avatar
Flash has to be done at the dealer. Sensors can be installed by anybody, as long as its done correctly.
Old Mar 1, 2012 | 01:08 AM
soundjunky's Avatar
has to be done on the books;
the tech has to get the reflash from GM - using your code and car's vin.
Old Mar 19, 2012 | 02:46 PM
yup.
The following links are actually from a website made by, and supported by the Performance Division;
GMTunerSource.com - LNF Stage 1 Warranty Information
Does anyone have the warranty bulletin # for the cobalt ss the page above only lists bulletins for solstice and sky. i just called to get gms1 installed and the dealer said it might void my warranty (which i know is false). i just need proof.
Old Mar 19, 2012 | 04:49 PM
  #36
soundjunky's Avatar
That post of mine which you quoted gives you the warranty info ~ it was in fact specifically about the GMS1 on the Cobalt!
Old Mar 19, 2012 | 06:32 PM
  #37
SSam2.4's Avatar
#ACC09-004 and #ACC08-039.
Old Mar 19, 2012 | 06:59 PM
  #38
Dart_SI's Avatar
Can u get just the sensors without a flash? Id like my scan gauge to read more than 22.7 psi.
Old Mar 19, 2012 | 07:49 PM
  #39
soundjunky's Avatar
yes you can.
you can even buy just the upgraded MAP's and CED pigtails (because the plugs are different) ;
BUT!!!
When you change MAP's the resistance values for any given vacuum/boost are read differently - so the tune has to be calibrated to the MAP's being used.
Old Mar 19, 2012 | 09:07 PM
  #40
09TcSedan's Avatar
2 of the techs i talked to a day prior of installation said it would void warranty...
Old Mar 19, 2012 | 09:19 PM
  #41
soundjunky's Avatar
what a bunch of blithering idiots.
the only thing that could be used against you is hte CED pigtails ~ and only because they're not *official* GM parts;
but even still, any problem resulting in warranty work would have to be clearly show to be at the fault of the pigtails...
A it happened I messaged Tom last fall about advice for making my own plug & play pigtials (looking for his "thumbs up" or "thumbs down" on if I had selected the correct male and female ends ~ when he told me that he was in the final phase of testing his pigtails ~ which he subsequently started selling...
I don't know if I was the first person to get these, but I was definitely one of the earlier guys to get a set.
Tom & CED FTMFW!
Old Mar 19, 2012 | 09:22 PM
  #42
09TcSedan's Avatar
yea but then again they aint too familiar with cobalt ss/tcs
Old Mar 20, 2012 | 01:08 PM
  #43
Shanedude's Avatar
The techs should've looked further into it instead of saying straight up your warranty will be voided. That's the #1 selling point on GMS1 for jebus sakes.
Old Mar 20, 2012 | 04:05 PM
  #44
guitarenvy's Avatar
Originally Posted by TommyP
dealers don't get informed of every upgraded part that comes out. It's basically that they're all qualified to install it but don't expect them to be experts just because they work at a GM dealership. Most just get general training in the car, then anything else they have to rely on experience and the detailed instructions GM gives them. It's not exactly a difficult install so any should be able to do it, especially if you get the kit from CED with the wiring adapters.
THAT explains it fully.
Old Mar 30, 2012 | 05:46 PM
  #45
I just called a different dealer(Muzi Chevrolet) and they installed it without giving me any bullsh*t.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
dieGone
Oct 1, 2015 06:27 PM
