fluttering noise in 5th gear
Old Jan 20, 2012 | 12:44 PM
redman2357's Avatar
Has any one experienced a fluttering noise when you are in 5th gear and step on the gas, what is causing this?
Old Jan 20, 2012 | 12:46 PM
HyperMuffin's Avatar
You shouldn't be stepping on the gas in 5th gear.
Old Jan 20, 2012 | 12:47 PM
Chevycobaltss3's Avatar
Lol no no buddy. Your putting to much of a load on the turbo and the engine and ect.
Old Jan 20, 2012 | 01:09 PM
SSlobalt's Avatar
Everyone repeat after me: 5th gear is an overdrive.
Old Jan 20, 2012 | 01:45 PM
redman2357's Avatar
Lol, did not know, so its better to downshift to 4th if I wanna pass someone?
Old Jan 20, 2012 | 01:47 PM
SSlobalt's Avatar
3rd to pass. If you want to get past them in a hurry.
Old Jan 20, 2012 | 02:07 PM
Gremlin85's Avatar
Never hit boost in 5th.... well, at least not in low rpm's.
If you're on the salt flats and going for top end speed, then boost in 5th is fine
Old Jan 20, 2012 | 02:11 PM
5th is you're overdrive cruising gear with minimal throttle. 4th is basically a high way passing gear. I still wouldn't floor it in 4th though at high way cruising speed but it is safer to give it a bit more throttle in 4th when at highway speed.
SSlobalt's Avatar
You'd probably melt something, anyway.
Old Jan 20, 2012 | 02:20 PM
rogersj's Avatar
defently 3rd for passing lol
Old Jan 20, 2012 | 03:54 PM
alerosaint's Avatar
Never wot in 5th....you can give it a lil juice to pop out and scoot a lil....for a decent normal pass put it in 4th...even then i wouldnt WOT pass...to blow some doors off passing with the rage of the SS turbo gods downshift to 3rd and dont forget to rev match...and WOT to your heart contents...but careful cause you will be doing 100 in no time flat especially if your tune is brutal.
/.02
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
