Headgasket Replacment?
Old Oct 5, 2010 | 02:57 PM
mkulrey13's Avatar
So...Anyone have a how-to for the LNF..........?
Old Oct 5, 2010 | 03:04 PM
ChevyRockstar's Avatar
uh-oh
Old Oct 5, 2010 | 03:31 PM
RYRO14's Avatar
In for story
Old Oct 5, 2010 | 03:41 PM
jonxxxedge1's Avatar
Originally Posted by RYRO14
In for story
agreed
Old Oct 5, 2010 | 03:43 PM
hawlyns711's Avatar
heard about that after I got home from the cruise, bummer!
Old Oct 5, 2010 | 04:11 PM
ItalianJoe1's Avatar
How'd you blow the HG?
Procedure is exactly the same as any other ecotec motor. Remove piping and manifolds, valve cover, front timing cover, timing chain, head bolts, lift off head.
Old Oct 5, 2010 | 04:13 PM
BYT*SS*TURBO's Avatar
That sucks man
Old Oct 5, 2010 | 04:24 PM
glen229's Avatar
not hard, just time consuming, get yourself a set of ARP studs tho
Also when putting the head back on remeber inside out, i'll try and find the pattern chart for torquing
Old Oct 5, 2010 | 04:26 PM
glen229's Avatar
its a constant circling, like that game snake lol a spiral torque sequence
Old Oct 5, 2010 | 04:27 PM
glen229's Avatar
head torque specs?
Old Oct 5, 2010 | 05:14 PM
Make sure you retorque the head if you use those... Most people don't.
Old Oct 6, 2010 | 06:29 PM
mkulrey13's Avatar
How-to anyone?
Old Oct 6, 2010 | 06:30 PM
tom.g's Avatar
How did you blow a headgasket?
Old Oct 6, 2010 | 06:46 PM
Dart_SI's Avatar
you tell us how u did it, then we will tell u a how to. what u think u get free advice on here?
Old Oct 8, 2010 | 12:07 AM
army_greywolf's Avatar
There is a procedure to torque to spec + 1xx degrees that will dial you in at the correct torque after stretch, thus not requiring retorque. However, high horse engines should retorque REGARDLESS.
Old Oct 8, 2010 | 12:09 AM
glen229's Avatar
i did an additional 70 degrees, as that is what they instruct you to do
Old Oct 9, 2010 | 04:20 PM
good deal. fifteen years ago what BYT said would absolutely be true, but technology and heat treatment practices and lots of testing have come to the conclusion they can nail down the correct clamping pressure right out of the box.
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
