Help evap code!!???!!??!
Old Aug 14, 2012 | 05:41 PM
widowedeight's Avatar
Hi for like the last year I have been throwing an evap code, bone stock or modded, the only symptom I have noticed is when I get gas it takes forever to crank over
I have looked on here and all I have found is this
"Evap code coming back over and over ended up beeing my HPFP+Purge. She have a hard time starting sometimes when you get gas?"
I sent a pm to the person that posted that but I was hoping for a quick response, anyone have this problem, it's so embarrassing sitting there and having my motor crank for 20 seconds at the gas station
Old Aug 14, 2012 | 06:03 PM
Ok so now I know that hpfp stands for high pressure fuel pump but I still don't know what the problem would be with it/ if I wold need to get it replaced, I'm assuming that isn't under warrenty lol
Old Aug 14, 2012 | 07:47 PM
SSlobalt's Avatar
Go to Youtube and search EVAP. You'll see a video explaining to you how to remove and test your EVAP solenoid. The video is on a Sky, but it's the same drivetrain.
Old Aug 14, 2012 | 08:42 PM
Kk thank you
Old Aug 14, 2012 | 08:45 PM
JacBlackSS/TC's Avatar
you need a new evap purge soleniod it takes about 2 seconds to switch it out and it cost about 20 or so bucks to get one. you can get around it by filling your tank up half tank and not when it gets to empty.
Old Aug 14, 2012 | 09:02 PM
SSlobalt's Avatar
DDMWorks - EVAP Solenoid Testing and Replacement on Ecotec engines - YouTube
Now that I'm home, I can post the link.
Old Aug 14, 2012 | 09:10 PM
SSlobalt's Avatar
Also watch this video if you really want to know how the EVAP system works. It's boring, but effective.
Automotive Evaporative Emissions - Part One - YouTube
Old Aug 16, 2012 | 07:07 AM
Thanks that was a lot of help, today I will check to see if my purge solenoid is stuck open but does anyone have a picture of where the vent valve is? If so is there a way to check that?
Old Aug 16, 2012 | 09:46 AM
Stamina's Avatar
https://www.cobaltss.net/forums/5495711-post178.html
Old Aug 16, 2012 | 09:55 AM
ginger's Avatar
there are alotta threads on here about the purge evap solenoid. i think weve all had this problem pretty much.
Old Aug 16, 2012 | 01:45 PM
Getting the vent valve today, and I forgot to mention that I have already replaced the purge solenoid once lol
Old Aug 17, 2012 | 01:18 PM
The new valve requires an adapter for future notice for anyone having a similar problem
Old Aug 17, 2012 | 02:43 PM
RobSSsedan's Avatar
I had the same problem and a new purge valve fixed it. I bought it on ebay.
GM Pontiac Buick 12608378 Vapor Canister Purge Valve, Same as ACDelco 214-2125 | eBay
Old Aug 17, 2012 | 04:45 PM
Stamina's Avatar
Are you sure you got the right one? What was the part number for the vent valve?
Have anymore information on the adapter, such as pics or the part number for that? This is the first anybody has said anything about that.
Old Aug 17, 2012 | 06:24 PM
It is what my parts guy said at work (I work at a body shop) we got it directly from the dealer
Old Aug 17, 2012 | 06:28 PM
That is the one on the manifold right I had replaced that already but I still have the problem so maybe I will check that again cause I am stumped
Old Aug 17, 2012 | 07:46 PM
SSlobalt's Avatar
The vent valve is back at the tank and gives a p0451, I believe. The Purge Solenoid is on the intake manifold.
Old Aug 20, 2012 | 08:41 PM
Replaced both and still having the problem maybe I need to cut the one bolt down on my exhaust off the top of the dp a lil cause I cross threaded one of the bolts the day before this happened so maybe that slight gap of having only 3 bolts tight off the top flange is causing this, if that is even possible...? I'm just flummoxed by this one...
I assume if it isn't that then I have a boost leak somewhere any common places I should check/how to check, I already checked the fmic
Old Aug 20, 2012 | 08:44 PM
Dart_SI's Avatar
yea i bypassed my EVAP system. screw that crap. lol.
Old Aug 20, 2012 | 09:15 PM
How? I'm just so f'ing temped, I just wish I would boost more than five lbs it makes me sad
Old Aug 21, 2012 | 05:38 PM
Boosting normally now not sure why but not complaining
Old Aug 21, 2012 | 09:06 PM
SSlobalt's Avatar
It's a Cobalt. It'll come back when you're out of state.
Old Aug 21, 2012 | 09:17 PM
Rofl o no going outta state Thursday!!!! Lol
Old Aug 22, 2012 | 12:52 AM
SSlobalt's Avatar
BWAHAHAHAHAHAAAA!!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
