Holy crap zzp pcm tune
Old Sep 24, 2015 | 03:21 PM
  #51
KMO43's Avatar
Originally Posted by TedSS
Thanks guys for your replies. I don't spin hard in 3rd but it does break loose a little bit, like I said I have bald worn-out original continentals on there still. A lot of things changed when I added the new tuned pcm in. For example it warms up a lot faster and runs cooler, the fans come on a lot sooner and cools it down. Basically it's a nice tune and pulls a lot harder than I thought it would. I'm gonna check the KR and AFRs and LTFT soon but I dont notice any problems. If I add a downpipe and intake would I still have a problem with the "learndown" feature? I'm assuming I would. But hopefully ZZP will retune the pcm when I do add some bolt-ons.
Learn down is gone with HPT but when you change parts you need to get the tune updated
Old Sep 24, 2015 | 04:14 PM
  #52
turbocharged717's Avatar
This^ it's best to put on everything you want and tune once.
Old Sep 24, 2015 | 04:27 PM
  #53
TedSS's Avatar
Yeah I agree but didn't do that lol. I really should have but I didn't have the money for what I wanted. I wanted a downpipe and intake .
Old Sep 24, 2015 | 04:58 PM
  #54
KMO43's Avatar
If you have ur own HPT some tuners give free retunes so then it doesn't matter
Old Sep 24, 2015 | 08:53 PM
  #55
kzak104's Avatar
Originally Posted by Matt M
My hater comment is based on all the people that jump in and say there's no way you are spinning your tires, it must be your clutch, you must have crappy tires, etc...
i believe second, doubt third, unless he has some terrible tires, not being a hater...
Old Sep 24, 2015 | 08:56 PM
  #56
TedSS's Avatar
No hating here, my tires a pretty freaking terrible. I can break loose in 3rd, no bullshit
Old Sep 24, 2015 | 08:59 PM
  #57
TedSS's Avatar
Alright so this post is way off in left field and way off topic. What is a muffler delete? I keep hearing people talk about it and I'm really curious.
Old Sep 24, 2015 | 09:16 PM
  #58
Just what it says you remove the muffler lol
Old Sep 24, 2015 | 09:23 PM
  #59
Devin86's Avatar
Do you have to know the vin # for the pcm you send in?
Old Sep 24, 2015 | 09:33 PM
  #60
TedSS's Avatar
Haha oh really, so you just take a saw and cut that son of a bitch off?
Kinda like a rice burner
Old Sep 24, 2015 | 09:34 PM
  #61
TedSS's Avatar
Yes I think so because that's how it's matched to your car, but I could be wrong.
Old Sep 24, 2015 | 10:59 PM
  #62
Devin86's Avatar
Im just sending in a different pcm its just a core anyways i think they use used cores so they must rewrite vins i hope. I dont need two pcm's i just wanted to test there tune without sending in my stock pcm
Old Sep 25, 2015 | 04:30 AM
  #63
KMO43's Avatar
I know their tune
[QUOTE=TedSS;7566934]Haha oh really, so you just take a saw and cut that son of a bitch off?
Kinda like a rice burner[/QUOTE
Old Sep 25, 2015 | 11:20 AM
  #64
no_ss's Avatar
Muffler delete is a pipe in place of the big boxy muffler
Old Sep 25, 2015 | 11:23 AM
  #65
Yup or you buy a catback without the muffler. Either case you just get rid of it
Old Sep 26, 2015 | 01:01 AM
  #66
taintedred07's Avatar
Originally Posted by Shanedude
Intercooler/charge pipes are not needed for stock turbo. Only time is upgrade is IF your stocker breaks or if you go bigger turbo. Some people cry you need them for reliability but its rare to bust the stock charge piping and the stock IC is overkill for this car, unless you smash it on something then might aswell go after market since price will be similar to stocker.
Old Sep 26, 2015 | 09:03 AM
  #67
Rayray2781@gmail.com's Avatar
Have a question that maybe you or someone else can answer regarding my 2010 colbalt SS turbo. I recently put on a catless DP with a 02 bug for the first day it did not throw my Cel. The second day it did throw my Cel, so I ordered a straight extension Defouler, do you think that will fix the cell fix I had the car diagnostic and the code was P0402 - meaning no cats.
Old Sep 26, 2015 | 11:20 AM
  #68
It should fix the problem since your getting the on farther away from the stream
Old Sep 26, 2015 | 11:29 AM
  #69
By having this down pipe will this hurt my vehicle in any way or is this actually better for the stock turbo?
Old Sep 26, 2015 | 11:46 AM
  #70
If you tune for it it will be better
Old Sep 26, 2015 | 11:55 AM
  #71
If I decide to tune it will that affect all the other stock parts in the vehicle. Or will I have to start upgrading the Pistons the fuel injectors etc?
Old Sep 26, 2015 | 11:59 AM
  #72
The tune will help you add the power benefits of any mods you do to do car plus make it run alot better. Also depending on the tuner. You don't have to upgrade the injectors or pistons unless your planning to make big power on the car and that's probably doing a turbo swap etc
Old Sep 26, 2015 | 12:00 PM
  #73
KMO43's Avatar
Do your research on tuners and you'll be really safe no need to rebuild and some offer free retunes
Old Sep 26, 2015 | 12:01 PM
  #74
KMO43's Avatar
I dynoed at 481hp on 100% stock engine
Old Sep 26, 2015 | 12:03 PM
  #75
Yup that's a great example you don't need to upgrade ^ but if you want alot more than that then upgrading wouldn't be a bad idea
