if you use NLS when your clutch is starting to slip, will it redline?
Old Aug 26, 2011 | 12:17 AM
Dart_SI's Avatar
i only use NLS when im having a close race with someone. anyway, against a camaro... i NLS from 2-3 and notice that my rpm jumps to redline real quick then jumps down. normally the rpm just goes right down since its in the next gear, and doesnt redline (mines set at 7k)
ive used NLS tons of time, so i know how to do it. anyway, i think my clutch is starting to slip a little too. (noticed this today on a 3rd gear pull at 60mph ever so slightly)
would a slipping clutch cause my rpm to jump up to redline for a sec when i use NLS?
if i cant figure it out im probably going to stop using it till i get a zzp stage 4 clutch.
Old Aug 26, 2011 | 07:11 AM
Dart_SI's Avatar
Bump for info. Tried it again today. I still get the pop but it still goes to recline for a sec too
Old Aug 26, 2011 | 07:29 AM
donkeyballs's Avatar
Its probably slipping I have made my hyper single slip from spinning in second and shifting into 3rd to soon. It will be at 26psi of boost and its too much tq at low rpm but it only happened a few times. I would drive it really easy for awhile and it will deglaze your clutch and will get you by till you get the stage 4.
Old Aug 26, 2011 | 08:17 AM
SOHC24powa's Avatar
if your on a stock with a 30psi tune I'm surprised it's lasted this long. when first got my zzp PCM it was their 22psi tune but had a 26-28psi spike. I think I got one or two pulls in without slip lol. but all my slip was coming from the spike, if your holding 30psi further towards redline you probably will experience more slip.
Old Aug 26, 2011 | 08:21 AM
steven2008ss's Avatar
you are NLS at redline right
Old Aug 26, 2011 | 08:28 AM
Dart_SI's Avatar
Recline for me is 7k. I shift at 6 tho since power falls off at 5800.
And my tune doesn't hold 30, it tapers off to about 21 psi by recline.
Old Aug 26, 2011 | 08:33 AM
that IS SO BAD for the clutch youre suppose to do it like legit redline
Old Aug 26, 2011 | 08:38 AM
Dart_SI's Avatar
I've always done it at about 6-6.3 k. Never had problems with it till yesterday. I guess I prolly just need a clutch.
Old Aug 26, 2011 | 09:08 AM
RoadconeTuning's Avatar
yes, your clutch is toast... quit racing it... if your hyper single slips the you probably need to burn the trash off the flywheel, that thing shouldnt slip either...
Old Aug 26, 2011 | 09:12 AM
Didn't you just get new tires with more grip? They killed your clutch and you were spinning before instead of slipping. You should have no problem NLS @ 6k if your doing it fast enough cause I know I never had a problem doing it before redline.
SOHC24powa's Avatar
yeah i didn't mean hold full boost until redline. further towards redline than where mine spikes. get a clutch haha
Old Aug 26, 2011 | 09:17 AM
They will slip with enough power and I know 09pshhh or whatever his name is has had his slip also. It grips like crazy but has slipped on rare occasion.
Old Aug 26, 2011 | 09:18 AM
Dart_SI's Avatar
Im in the stock clutch. Lol. I just read somewhere that sometimes when you nls your tach will just jump to redline real quick then drop down. When mine doe it it sounds like a normal nls. No bouncing off the recline. Ill get a vid later. Oh yea, my map sensor is blown too. maybe I should get that fixed before I race again. Parts in the mail
Old Aug 26, 2011 | 09:46 AM
Dart_SI's Avatar
Here's a vid. Notice how the nls sounds properly done but the rpms jump. Also that is wheel spin not clutch slip in 2nd gear.
NLS - YouTube
Old Aug 26, 2011 | 10:15 AM
SOHC24powa's Avatar
everything sounds fine to me. i think when you nls that low it doesnt pull timing and hold the rpm like it would if you nls'ed at redline, so you wouldnt really be nls'ing but powershifting. or i could be totally full of crap, thats just my theory.
Old Aug 26, 2011 | 10:23 AM
BartSS's Avatar
^^ this
Old Aug 26, 2011 | 10:26 AM
cranemaster's Avatar
My car is like this now too... you can NLS still, its just way harder. Timing wise, as if the clutch is worn out a bit.
Dart_SI's Avatar
If it didn't pull timing it wouldn't pop like it does. Also you can't hear the car rev to 7k even tho the tach. Goes to it. Its a head scratcher.
Old Aug 26, 2011 | 10:35 AM
No I meant timing as in the amount of time you have to complete the NLS lol, it seems like a smaller window as the clutch get more worn out. Haha
Old Aug 26, 2011 | 10:43 AM
Gremlin85's Avatar
I agree with this ^
The video you posted is showing you powershift. Mine did that when I raised my redline to 7k and tried nls'ing towards 6200 rpm. Doesn't work.
Old Aug 26, 2011 | 10:58 AM
ATLsilverSS's Avatar
I agree here. i haven't nls'd in a long time but if i did and short shifted it the rpms would spike just like yours did
Old Aug 26, 2011 | 11:05 AM
Dart_SI's Avatar
Well damn. So moving the recline up moves the NLS window up as well. I think I want my recline lower anyway. 7k is not needed on stock turbo.
Old Aug 26, 2011 | 11:41 AM
robk's Avatar
Mine does the same thing as darts, sound and everything. So wut it seems like people are saying is nls'ing w a 7k redline should be done closer to the redline?? Cuz ive always nls'ed between 6-6.5k even on my old tune.
robk
Old Aug 26, 2011 | 02:21 PM
Permafried-'s Avatar
Hmm, if I NLS too early, I don't get the exhaust gurgle, instead I get only the BPV sneeze. My RPM also don't jump up past the point where I shifted either. Perhaps yours being custom tuned is doing that because the NLS point is still set to 6250, but the vehicle is allowed to rev to 7000? I suppose this depends on how the NLS algorithm works at the ECM level. Does it just look at redline - x, or is it a solid value range that can be adjusted seperately?
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
