K&N Intake for SS/TC
Old Jun 2, 2010 | 07:07 AM
  #551
CudaJoe's Avatar
Originally Posted by sptrdss
can you guys snap a pick of the rotated filter and where it seems to be best as I don't have the rpd.thks
haha Im working on that. At 45 degree angle for stft's, I get 7.0 to 8.0 when throttling and when cruising I get -7.0 to -9.0
By far, this is the worse way to have your intake situated. My ltft's however = -3.1
Im going back to the 90 degree angle maybe. is negative better to have than positive fuel trims?
Old Jun 2, 2010 | 09:24 AM
  #552
swazzees's Avatar
Originally Posted by Stamina
It's a hardware tuneable intake! Just twist the filter and go! lol
funny...............
Im disapointed that nothing works really good.....
this system sounds sick in the vid posted earlier
Old Jun 2, 2010 | 10:37 AM
  #553
Stamina's Avatar
Overall, the closer to zero, the better.
If you have to pick being off one way or the other though, pick negative. That means that you're rich and taking out fuel to compensate instead of being lean and adding fuel to compensate.
Old Jun 2, 2010 | 03:00 PM
  #554
SRVisGod24's Avatar
I just saw the video of this system myself, and man, it needs to hurry up and come out!!
Old Jun 2, 2010 | 03:25 PM
  #555
northvibe's Avatar
it is out... I think its just out of stock now.
Old Jun 2, 2010 | 06:12 PM
  #556
SRVisGod24's Avatar
Sorry if I missed it in any of the other number of threads on the K&N filter. But for those of us who don't have the bracket/bolts on our cars, does K&N have a solution for that now?
Old Jun 2, 2010 | 06:16 PM
  #557
HB_SS/TC's Avatar
Sorry if I missed it any of the number of threads on the K&N filter. But for those of us who don't have the bracket/bolts on our cars, does K&N have a solution for that now?
Yes they do give them another week and call to see if they have the parts
Old Jun 2, 2010 | 06:25 PM
  #558
SRVisGod24's Avatar
Sweet! I know you're like the guinea pig for this haha. Is that the part, the bolt that's screwed into the hose?
Old Jun 2, 2010 | 06:30 PM
  #559
HB_SS/TC's Avatar
It's the L shaped bracket to the right of the maf sensor
Old Jun 2, 2010 | 06:32 PM
  #560
SRVisGod24's Avatar
That's what I thought it was. Thanks for clearing that up. How does it attach to the plate?
Old Jun 2, 2010 | 06:36 PM
  #561
HB_SS/TC's Avatar
My car and many others don't have the plate.
The new bracket bolts to the valve cover like you see in the pic
Old Jun 2, 2010 | 06:42 PM
  #562
SRVisGod24's Avatar
Alrighty, I see that, thanks again for clearing that up
Old Jun 2, 2010 | 06:48 PM
  #563
cdlumb's Avatar
Just wondering with the fuel trims, what is the stock air box, is always at zero or is it positive or negative at times? Really is there a big diff. between k&n and factory?
Old Jun 2, 2010 | 08:29 PM
  #564
jarhead's Avatar
thats the way I did have it. It was giving me positive fuel trims. Then I rotated it 90 degrees so the bulge part of the filter was away from the engine and I got negative fuel trims. lol.
Im trying a 45 degree angle and see what happens next. I loved the negative fuel trims. very responsive!
Well Cuda Joe there is something to this filter position, With the filter hole at the top of the inlet ltft's were +7, I rotated it 90 deg and drove 40 some miles mixed city and highway and now ltft's are at +0.8 with very little shift on stft's aswell. I then just now went to the k&n video install in the other lnf section and that is how they have it also the hole more towards the bottom and the bulge at the top. Also look at the pic on the first page of this post the original beta tester is the same way. Good observation on the fuel trims and thinking of switching the filter, I was very skeptical about this but you were right. Will keep monitoring the trims over a longer period of time.
Old Jun 2, 2010 | 11:19 PM
  #565
CudaJoe's Avatar
hahaha, yea. I told ya. I noticed it when I took the intake out and reinstalled it and put the filter in so that it was further away from the engine. filters back to 9 o'clock (when facing the car) right now my car shows a -8.0 ltft. and for stft's, I get somewhere between -3.0 to -6.0 when cruising. BUT when WOTing it or just throttling it, it corrects to 0.0 exactly. not higher or lower. pretty neat!
Old Jun 2, 2010 | 11:37 PM
  #566
turbaltss's Avatar
I'll be ordering the filter that comes in the kit tomorrow to see if it does the same for my cia sri. Possible cheap fix for airflow
Old Jun 3, 2010 | 07:22 AM
  #567
CudaJoe's Avatar
Im no scientist (actually...I am) but I think this phenomena has something to do with the fact of how the filters location is like an inch or two from the sensor on top of the fact that rotating the bulge of the filter upwards allows the air coming through the slit of the hood to enter the filter. Rotate the filter down and less air rushing through the slit of the hood (where it meets the bumper) reaches the filter.
Basically I dunno what kinda results could happen on the CIA, but your welcome to try it and let us know.
Old Jun 3, 2010 | 11:55 AM
  #568
turbaltss's Avatar
Basically I dunno what kinda results could happen on the CAI, but your welcome to try it and let us know.
I think you transposed a couple of letters cia (clear image) sri... That's what you get when your posting so early in the mornin'!
Old Jun 3, 2010 | 12:29 PM
  #569
CudaJoe's Avatar
meh, fixed . A man's gotta work. or actually go to work and get on the computer and post in these threads, lol.
Old Jun 3, 2010 | 08:54 PM
  #570
sptrdss's Avatar
I called K & N about the intake tube bracket that is supposed to be on some of our cars,it is not on mine and they have told me when they come out with a bracket it will be shipped to me.Also I gather from what I am reading that I should rotate my filter so the bulge is at the top,for proper air so to speak.Can anyone tell me if this has in fact improved the response or performance of the SRI?Thanks
Old Jun 3, 2010 | 10:53 PM
  #571
SSPROVIDENCE's Avatar
my K&N has so far caused me alot of issues...the first day it was installed it ran great...and sounded amazing...the next day on my way to work i got the check engine and ever since that my car is running on engine power reduced...think i might have to go to the dealer...ive already tried many things...even totally unassambled and reassembled and installed that intake again. reset battery...what else could be wrong...any ideas before i have to take it to the dealer?
Old Jun 3, 2010 | 11:42 PM
  #572
ford's Avatar
User error.
What code did it give you? Since it ran good for a while i would say it is possibly something came loose. Maybe a connection or something. Pull the code and see what it says first.
Old Jun 4, 2010 | 12:08 AM
  #573
HB_SS/TC's Avatar
You don't even have the k&n intake
Old Jun 4, 2010 | 01:59 AM
  #574
jarhead's Avatar
Yes dramatic difference mine after turning the filter the right way up. After 250 miles is +.08 ltft and was 0 a good part of the day the most ltft got to was +3.9 and that was when I was doing a lot of pulls checking some things. The stock box and filter ss/tc we checked was at -4.7 ltft's so I am really happy so far.
Old Jun 4, 2010 | 05:14 AM
  #575
sptrdss's Avatar
So with regard to the location of the cone filter,the bulge connection part of the filter would be at the 12 o'clock position which would put the flat side at the bottom,is this correct?Thanks
