K&N Intake for SS/TC
Old Jun 11, 2011 | 03:37 AM
  #1251
RyanJM's Avatar
I started with injen but kept getting ceo codes so swapped it with modern performance for.the k&n and it set the cel off till I clocked in in a few different positions.11 worked good for me with no knocking. I also run only.93 since I.don't trust 89 in anything except my trailblazer which gets 87 and 89 no 91 around here that I have found. I was going to get the forge but.figured the oil catch would be a better investment at the moment since I only have 23k on the car and helped a lot with my TA.
Old Jun 11, 2011 | 11:03 PM
  #1252
09SSsleeper's Avatar
Question
Originally Posted by SuperSlow
Does anyone have any hood clearance issues? With the filter at 12:30 it sits pretty high. I dont think its actually touching the hood but its damn close.
yeah my filter is actually rubbing on the hood, it shows a grey grease on the hood, but the filter is fine otherwise. anyone have any solutions?
Old Jun 15, 2011 | 09:21 PM
  #1253
SuperSlow's Avatar
I've since confirmed that my filter is rubbing. I think it has more to do with the position of the filter at 12:30. I'm going to try and reposition the intake tube slightly to see if that can buy enough clearance.
Old Jun 22, 2011 | 09:35 AM
  #1254
Domesticboost.com's Avatar
So after having my k&n on for a few months it's the same deal as the rest of the intakes unless your completly stock this needs to be tuned my car started sounding funny on cold starts then a cel popped up misfire, manifold pressure, and fuel codes all came up i'm running the gms1 kit and all i can say is as soon as i took it off wham car runs good starts properly ect so don't count your chickens before they hatch this is my second attemp at a intake i ordered hp tuners new beta to see if you can even fix this cold start issue to much air is being sucked in to fast in my opinion and yes i was getting some serious turbo flutter this car is really annoying to do up
Old Jun 22, 2011 | 10:30 AM
  #1255
SSam2.4's Avatar
I have gm stage 1 and the K&N SRI and I have had no codes to this date. I have about 15000 km on the SRI.
Old Jun 22, 2011 | 12:34 PM
  #1256
rukkee's Avatar
I'm pretty sure you can get rid of the cold start cat warm up ..... It was tuned out of my car by Trifecta.
These car's are so maf sensitive that I'm not surprised that people have issues .... when I was running the superchips canned tune ....just a K&N air filter threw the trim's to -10 LTFT .
I have a K&N intake coming this week so it will be intresting to see how bad the trims are until I have the tune adjusted.
Old Jun 22, 2011 | 12:53 PM
  #1257
Tomtwtwtw's Avatar
Ditto, absolutely no problems with it. Guy above should double check GMS1 install and filter placement, sounds like something else is off.
Old Jun 22, 2011 | 01:21 PM
  #1258
SSam2.4's Avatar
^ I agree with you.
Old Jun 22, 2011 | 02:03 PM
  #1259
BPacak's Avatar
Vtec Rep
i had mine on my car for a month our 2 before getting tuned no problems. and now that im tuned i dont get the crazy vacuum noise on a cold start up, i miss it lol.
Old Jun 23, 2011 | 05:31 AM
  #1260
I had it on for 4000kms so give it some more time it's only on the cold starts it would mess up it's weird i've had 2 intakes on the car both installed by a good mechanic i have a truck and a another i run cold airs on both with full exhaust with no problems he installed, It worked amazing for awhile then started losing power nasicly and misfires on cold starts just like the aem did i bought hp tuners new beta be here in a few weeks i put the stock air box on works good agaain but basicly unless you have a way to log your car i don't see how you could know that your not having issues already a cel don't show up for every misfire on this car for some reason but it will if you scan it!
Old Jun 23, 2011 | 11:37 AM
  #1261
CudaJoe's Avatar
UMMMMM has anyone noticed on the K&N website that this intake is illegal in a bunch of states now? Including Maryland, PA, MA, ...etc...???? I swear it wasnt before? what does this me when its time for emmisions?
Old Jun 23, 2011 | 11:46 AM
  #1262
ford's Avatar
Doesnt the intake already have a "legal in 50 states" badge on it? I forget its been a while since i checked the little plaque on it.
if it does id just refer to that if questioned.
Old Jun 23, 2011 | 11:50 AM
  #1263
CudaJoe's Avatar
yeah, it mentioned that sticker on the site as well, I wasnt sure if that is the sticker on the intake, lol.
Old Jun 23, 2011 | 01:12 PM
  #1264
Tomtwtwtw's Avatar
More states are probably adopting California's emissions policies, or something very close to it. Some of their stuff has been approved by CARB, but definitely not all. It's a hell of a process. (those who spent months waiting anxiously for GMS1 are well aware!)
Old Aug 4, 2011 | 01:38 PM
  #1265
jpv0521's Avatar
finally installed my k&n this past weekend after its been sitting in my room for about 6 months. first impression was holy **** it is waaaaay to loud at cold start up. i was in my garage and i cldnt even talk to my friend standing right next to me. but after 2 mins it becomes almost silent. then i gave it a few revs and it sounds amazing. im not a fan of squeaky loud BOVs so IMO the noise the bpv makes is perfect, just a nice clean whoooosh. however, i am still a lil disappointed that the annoying panda sneeze/barking noise is still there at higher boost under load, it just sounds upsetting and weird haha. Another thing i like is the loud turbo spool, it is like a suspenseful build up to the whooosh. haha. Only thing im concerned about is the fitment. Then pipe might not actually rub up against anything but it is extremely close to the firewall, like less then 1/8", and close to one of the mounting studs that holds the heat shield on, about an inch or so. This normally wld be ok, but the intake is mounted to the motor and those spots are fixed on the chassis soo when the motor rocks back and forth, which it will esp under hard driving, that pipe it going to smack the firewall and possibly the stud. Hopefully im wrong and everything will be ok but just something to look out for.
Summary:
Pros:
Amazing bpv sound (loud and clean at idle or medium boost)
Nice loud spool up
So much fun to drive
Cons:
Annoyingly loud at cold start up (not noticeable inside the car, but next to it or under the hood it is loud!!!)
Annoying bark frm bpv still there, and louder, at high boost under load.
Fitment is very tight but it does clear so only time will tell if this will be a problem.
Old Aug 4, 2011 | 01:57 PM
  #1266
CudaJoe's Avatar
There has been one K&N install that i've seen where it actually hits that stud and put a hole in the metal pipe of the intake. Keep an eye on that. fitment isnt gonna be directly the same on all cars nor will every single intake made be exactly identical when it comes to installing. If it hits, contact the company you bought it from.
As for your other cons there:
cold starts are loud on any car with a metal tube intake. that also includes other intakes on this car. You can get that cold start deleted with a tune.
the bark wont go away with a new intake. that noise is coming from the BPV. Your only solution is to get a mario coin/ "squeeky" aftermarket BOV.
Old Aug 4, 2011 | 03:32 PM
  #1267
RoadconeTuning's Avatar
Forge BPV seems to mellow out the bark, mine seemed to sound a little different compared to stock, i'm convinced that the stock rubber unit causes surge over about 8lbs...
Old Aug 4, 2011 | 03:38 PM
  #1268
BPacak's Avatar
Vtec Rep
i miss the cold start up noise lol
Old Aug 4, 2011 | 04:16 PM
  #1269
jpv0521's Avatar
hahahaha at "mario coin", i like that lol... but yea loud cold start ups will happen with any intake, i was just noteing it. I had the injen intake when i first bought that car tho and it wasnt as loud, maybe slightly less. if i rem correctly. but the louder bpv sound more then makes up for the loud cold start up. its honesly not even noticable on the inside of the car. just be aware, if u start gettin weird looks from ppl walking buy when u start ur car it might be cus they r going deaf haha
Old Aug 4, 2011 | 06:30 PM
  #1270
jpv0521's Avatar
btw the little adapter piece for the crank case blow buy hose, did u guys screw that all the way down? cus mine got about half way and then started to get really tight so i i tighted it a lil more and just left it.
Old Aug 4, 2011 | 10:18 PM
  #1271
Jellobriafra's Avatar
I ended up getting mine about 2/3 of the way in. After that it was so tight that I was afraid the round off the plastic hex. I figured if it was that tight it wasn't going to leak or come loose. I still check it from time to time though just to be sure.
Old Aug 5, 2011 | 07:30 AM
  #1272
CudaJoe's Avatar
it just needs to be snug, dont over tighten it. You want it to seal so no air gets by that it. Its not going to experience any pressure or anything.
Old Aug 5, 2011 | 07:52 AM
  #1273
Jhezzy's Avatar
well ordering my K&N intake this afternoon for my 2008 cobalt ss/tc. hoping i dont get a CEL. i still have factory warrenty till 2013 so i cant get a tune.
Old Aug 16, 2011 | 12:08 AM
  #1274
SC cobaltss15's Avatar
I am getting gms1 and kandN tomorrow.. should i be concerned about the combo throwing some cells?
Old Aug 16, 2011 | 02:52 AM
  #1275
jpv0521's Avatar
u guys really shld not have a problem with throwing cels with just an intake haha. unless u break something during the install haha. only problem u might see is ull be throwing ur fuel trims off, but u wont physically be able to notice that beside maybe some pops and crackles from the exhaust. This can also lead to reliability issues down the road but nothing to worry about in the short term. Also, if u have the gms1 tune, i have no personal experience with it but i have heard that it is much more picky then the stock tune and u might experience more of a problem, probably just larger deviations in ur fuel trims not like cels or anything, Although from wat ive heard gms1 gets very cell happy when u start modding with it. This is all hearsay tho so i wouldn't worry about it. Just something to keep in mind in case u do run into a problem.
