lambda question
Old Mar 12, 2012 | 12:44 PM
ManTFresh's Avatar
lambda question
my Lambda is 1.0 completly stock. with my catless dp i see fluctuation between .97-1.09. my AFR averages about 14.69 and fluctuates between 14.2-15.2 with catless dp on. does this seem normal? I have read some tuning threads to where lambda is .82 or .86. I understand my afr is a lil on the high side but i believe its fine. my lftf is -3.5 and my stft is about -2.3 and from what i researched, it seams to be ok. just wondering if im paranoid or if my car is running ruch. thanks for the help
Old Mar 12, 2012 | 01:12 PM
Gremlin85's Avatar
Are you talking about what you see at idle or cruising speeds?
A lot of what you're reading about the .82 or .86 Lambda is WOT tuning. WOT stock should be .87 up top I think. It goes form like a .95 around 2000 rpm and the drops to .93 at 4500rpm then .88 at 5000 and finally the .87.
You should see close to 1.00 Lambda anywhere else if completely stock tune. It'll fluctuate just a little, but alwasy hang around the 1.00.
Old Mar 12, 2012 | 01:15 PM
Bika's Avatar
Fail Less.
1.0 lambda = 14.7
.87 lambda = about 12.7
Old Mar 12, 2012 | 01:21 PM
ManTFresh's Avatar
oh ok i have not yet look at my lamda reading while going WOT. Its just my crusing speeds that i notice it. i didnt think i had a problem but i was reading WOT tuning n it made me wonder. thanks for the help
Old Mar 12, 2012 | 01:24 PM
Gremlin85's Avatar
Originally Posted by Bika
1.0 lambda = 14.7
^I forgot to add this in my first post.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
