LDK CRATE MOTOR coolant won’t read on the dash
brand new everything on the vehicle head to toe . I even just bought another coolant temp sensor and installed it but sill no change . It reads 61 F at first then once u ride it down the road it trips a cel and three dashes show on the display . I’ve read about thermostats but this thing is brand new . I suppose I’ll try that now but any other ideas would help p119 code
a quick google search shows p0119 being coolant temp sensor intermittent circuit. since you have tried another sensor and that didnt fix it, its more than likely a wiring problem. check the harness for any chafing or bare wires, check the pins to make sure they look ok and arent mangled (both the temp sensor and ecm).
