LNF bogs down under hard acceleration
Old Jun 5, 2015 | 06:58 PM
SR Tech's Avatar
There won't be many mechanics that will shell the valves. Most will just replace which =$$$$. Better off finding a fellow local SS'r who may have done it before
I just did mine 2 weekends ago, took about 5 hours start to finish, most of that was taping off and laying drop cloth cause that **** gets everywhere. If your not confident in yours skills don't attempt it because you can harm the motor
Old Jun 6, 2015 | 11:28 PM
Getaway_Driver's Avatar
Yeah, never mind. Nobody on the Ecotec group has done it, and I'm definitely not comfortable trying it myself. Called a shop and they wanted $700.
I'll just do seafoam and see if that helps out. Gonna do that next oil change, so another 3000 miles or so.
Old Jun 7, 2015 | 01:28 AM
umrdyldo's Avatar
Save the money. If the valves are bad seafoam won't do a thing.
Trust us. Nobody has any luck with it. You can't hardly get this stuff off.
Old Jun 7, 2015 | 09:37 AM
You're most likely right, umrdyldo, but it's hard to save money when you have expenses + college. I'll try to save for it anyway, but I feel like it won't get done until several months from now or even deep into 2016.
If seafoam doesn't help at all, I won't just act like the problem can't be solved. I know taking it in to have the valves cleaned would be wiser to keep the car running longer.
Old Jun 7, 2015 | 10:37 AM
SR Tech's Avatar
CRC makes a GDI intake valve cleaner that promises rainbows and lollipops but I haven't heard any amazing things yet. Still a very new product. I got 2 cans thinking I would soak the valves in that after shelling but didn't need to. Could be worth a try.
Seafoam will not touch it
Old Jun 7, 2015 | 05:58 PM
umrdyldo's Avatar
I seafoamed mine very oil change.
At 60k it took walnut blasting, soaking overnight in top end cleanr and wife brushed to clean mine
Don't waste beer money on seafoam. Keep searching for a member to help
Old Jun 8, 2015 | 03:52 PM
northvibe's Avatar
true..why waste money on seafoam if it doesn't do anything? Just wait until you has the money to get it done right.
I have a 2.0 ecoboost escape as well...same issue of course. But that IM seems to be easier to remove.....
Old Jun 9, 2015 | 12:14 PM
I can't find anyone who is either
A) willing to help with it
or
B) knows how to do it.
I'll just save the money for it, but it sucks because my car is being a pain when trying to accelerate. If I am in 3rd or 4th gear and I accelerate, it doesn't want to hit boost anymore.
I'm hoping it's just because my catalytic converter downpipe needs to be replaced asap.
Old Jun 9, 2015 | 08:18 PM
My car is in major limp mode. It won't accelerate past 6 psi, and it starts bogging down at 3k rpm. It wasn't doing this yesterday.
Could the bad cat be causing the limp mode? It's a significant loss of power. There's isnt a new code with the CEL either. It's still the P0420.
Old Jun 10, 2015 | 12:16 AM
brycerice13's Avatar
Try to tap the cat with a stick or something and try to listen and see if you can hear if it sounds like sand is in it. If you hear anything take it off the car and inspect it. I think it could be a clogged cat.
Old Jun 10, 2015 | 02:33 AM
  #36
Unique Crysis's Avatar
yes a bad cat can most definitely cause it to bog down, im almost certain that is your culprit, like Bryce said jack up the car and hit the cat and see if you can hear any type or rattle in there, if so your cat is bad and probably getting worse as you continue to drive it
Old Jun 10, 2015 | 12:22 PM
  #37
Okay, thanks, guys. When I get a chance, I'll go under and see if I can replace it. I've got a spare cat downpipe sitting in the garage, just waiting to be installed. I'm just lazy, and truthfully, a bit nervous, too. I just don't wanna mess something up. lol
But people have told me it's a really easy job, so I'll check it out in a few days.
Old Jun 10, 2015 | 06:16 PM
  #38
turbocharged717's Avatar
Its super easy just a few bolts and the o2 sensor and your gasket. Takes 15 minutes
Old Jun 10, 2015 | 07:47 PM
  #39
I'm not very mechanically inclined, so what might take 15 minutes for someone like you will surely take an hour for someone like me. Haha
I'm definitely going to give it a go in a few days, though.
Old Jun 10, 2015 | 08:28 PM
  #40
Kolt's Avatar
To bad your in SoCal. I could clean your valves and swap the dp for like 200 bucks lol. And that would include a full fuel system service with it.
Old Jun 11, 2015 | 04:49 AM
  #41
That would've been an awesome deal. lol
I don't think I can make the 1000+ mile trip, though! Haha
Old Jun 11, 2015 | 05:33 AM
  #42
Just go slow with the procedure there's a how to install on here I think it's called lnf down pipe install it will tell you the tools needed and what bolts to take off with pictures I believe
Old Jun 11, 2015 | 12:19 PM
  #43
exninja's Avatar
The only difficult part of taking out the downpipe is that you have pretty limited access to the bolts. You'll need extensions and u-joints.
I have tools, but I'm still 5 hours' drive away. I have the means to clean the valves but I've never done it. I got everything to do it, then my motor died and I got a new one.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
