Lnf oil capacity
Old Jul 19, 2010 | 11:15 PM
FF_ace's Avatar
Lnf oil capacity
This is a stupid question but how much oil does the lnf take?
Old Jul 19, 2010 | 11:18 PM
Br1anSStc's Avatar
5 quarts. its on here somewhere if you search. its in the manual too!
Old Jul 19, 2010 | 11:31 PM
CurrentlyPissed's Avatar
Any reason the LSJ takes 1 more qt?
Old Jul 19, 2010 | 11:58 PM
fakameanrepresent's Avatar
5 quarts
Old Jul 20, 2010 | 03:04 PM
ninja44's Avatar
The extra quart is for the separate oil cooler which the TC does not have.
Old Jul 20, 2010 | 03:09 PM
SunburstSS's Avatar
i thought the lsj take about 6.5 to 7 qts ? hmmmm
Old Jul 20, 2010 | 10:25 PM
Nighthawk243's Avatar
I've found it to be slightly below 6.5 quarts for the LSJ.
Pretty much your oil fill should be as follows:
L61/LAP/LE5: 5 Quarts Conventional/Synth 5w-30
LNF: 5 Quarts Synthetic 5w30
LSJ: ~6.5 Quarts Synthetic 5w30
Of course, you can use 0w30 or 10w30 without issues.
Old Jul 20, 2010 | 10:27 PM
zrated89's Avatar
mine takes 7 all the time every change. I would say 6 and 3/4 to be exact but i always use 7
Old Jul 20, 2010 | 10:53 PM
Wonder why they didnt put an oil cooler in the LNF, I thought it had one.
Old Jul 21, 2010 | 03:13 PM
SPLREDLINE's Avatar
My lsj takes 7 quarts since the first oil change. I have an 04 redline.Ii think it is odd for the lnf not to have an oil cooler since it is turboed.
Old Jul 21, 2010 | 03:22 PM
NWAE Cobalt's Avatar
although with 10w30, you need to let the oil heat up more before beating on it...and if you dont have an oil pressure gauge....that actually does take a lil bit
Old Jul 21, 2010 | 07:14 PM
Macgyver2484's Avatar
Our turbo is water cooled. It's not cooled by oil so that should not play a factor in why it doesn't have one.
Old Jul 21, 2010 | 07:16 PM
sundevil07's Avatar
told ya Nick lol
Old Jul 21, 2010 | 07:35 PM
Iam Broke's Avatar
The LNF has an oil cooler & heater, look at the laminated assembly below the oil filter cap off to the right a bit. It's a coolant over oil heat exchanger.
Old Jul 21, 2010 | 08:19 PM
the LNF is too awesome for anything more than 5 quarts.
Old Jul 21, 2010 | 09:19 PM
Malaclypse's Avatar
The turbo may be water cooled.. but the turbo shaft still needs oil. So techincally its water AND oil cooled.
As Iam Broke said, there's the sandwich oil to water cooler bolted to the side of the oil filter housing.
Old Nov 13, 2011 | 10:52 PM
bamaboy22's Avatar
I've changed my oil since Ive had my car and every time 5 1/2qrts.
Old Nov 13, 2011 | 11:14 PM
CrystalRedSS's Avatar
^^^this. For some reason, the dipstick doesn't read at all w/ 5 quarts in, but it'll read full after I put an extra half of a quart in.
Old Nov 13, 2011 | 11:19 PM
mikej's Avatar
mine was 5.5 as well and the computers at Oriellys said 6qts....im sure it all depends on if u change the filter everytime and if you are draining the oil when it is hot or cold and if you like the level to be in the middle of the dip stick or near the full mark
Old Nov 14, 2011 | 01:28 AM
bri2203's Avatar
I have heard that synthetic oil expands more than dino oil. So 5 quarts at 200+ degrees is more like 5.25-5.5
Old Nov 14, 2011 | 02:00 AM
rukkee's Avatar
This is from GM service information
2.0L L4 Engine Supercharged - RPO LSJ
6.3 Quarts
2.0L L4 Engine Turbo - RPO LNF
5 Quarts
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
patooyee
Oct 1, 2015 01:07 PM
