MAP sensor waveform
Old 11-05-2014, 05:43 PM
MAP sensor waveform
Well like tittle say anyone have a waveform for a map sensor in the intake manifold? I got one today seem kinda weird to me. I will be posting a pic as soon as i can. Also anyone have a weird ticking sound coming from around the intake manifold area. There is the obvious timing chain sound i mean one that sounds like a clock ticking.
Old 11-05-2014, 06:00 PM
I backprobed the map sensor signal using a Pico scope and got that wave form. Reason for asking for that ticking sound is because everytime it happened that would come up on the waveform (in different spots tho freezed the waveform to take pic). The sound has always been there since i got the car.
Old 11-05-2014, 11:20 PM
Or ok anyone know what are the typical symptoms of a bad map sensor on a lnf? Or how to test it if its still good?
Old 11-06-2014, 07:33 PM
SSlobalt's Avatar
The ticking is the hpfp. If you are talking about the TMAP, two good signs of it not working are positive boost pressure readings on the gauge when revving in neutral and a loss of boost signal on the RPD.
Old 11-06-2014, 07:38 PM
Actually just yesterday i did a pull and after i got down the freeway my rpd said it has no data available on the boost. Also weird thing im at 23 psi and it only went to 21 was kinda chilly last night
Old 11-06-2014, 08:49 PM
Joe09SS's Avatar
Mine says boost not available when I get on it sometimes it just doesn't read it right away.. It comes back shortly.
Old 11-06-2014, 09:11 PM
Well after that happened i left the car for a good 4 hrs went back said the same thing and then after driving a bit it came back but had never had that happened before
Old 11-06-2014, 09:56 PM
Joe09SS's Avatar
Yeah it's happened to me. Never really put any thought to it. I mean aftermarket tune with more psi boost its bound to say that sometimes
Old 11-06-2014, 10:12 PM
Yeah your probably right and i am on the stock map sensors
Old 11-06-2014, 11:57 PM
KMO43's Avatar
I had no data on my rpd I upgraded to the 3 bars now I haven't had a problem buy the sensors from CED and add to the tune
Old 11-07-2014, 12:02 AM
Yeah i want to buy them but my tuner charges me 75 to update the tune so i would rather just buy everything im missing then retune
Old 11-07-2014, 12:04 AM
KMO43's Avatar
do you have your own cable?
Old 11-07-2014, 12:24 AM
Nah i wish i did tho
Old 11-07-2014, 12:27 AM
KMO43's Avatar
Too bad I'd just send you the changes
Old 11-07-2014, 12:31 AM
Is that all i need the cable for someone to take a look of the tune i have atm? And if it is how much one run for?
Old 11-07-2014, 12:35 AM
KMO43's Avatar
What you need is just to update the sensor settings with HPT the tune can stay the same
HPTuners - HP Tuners #HPT-MPVI
Old 11-07-2014, 09:48 AM
So he wouldnt have to use a credit to add the new setting? in a way he wouldnt really have to charge me if he doesnt require to use one
Old 11-07-2014, 10:32 AM
blueLNFftw's Avatar
You only use 2 credits one time to "unlock" the car. After that you do not pay for anything you do to that car. Obviously the tuner may charge you for his time, but it only costs $100 to unlock your car and then he always has access to it.
Old 11-07-2014, 10:54 AM
Ohh then he has it unlocked already only thing is i have to drive like 1hr 30 to get to him and still pay to get it done lol so i would just rather buy intercooler and pipes and the sensors then get everything done at once
Old 11-09-2014, 01:07 AM
Got a CEL today still need to check it tho. Also what would cause a service traction light to come on and then throw me in to limp mode
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
anotherslowlnf
09-29-2015 03:52 PM
Adiaz1ss
09-26-2015 11:51 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: MAP sensor waveform
